paperpaper said:
It is possible with this and some other items the car could get down into the 24xxLBS range.
lol. that's the weight my car STARTED at :)
Yeah whats it weigh now lol
2850ish with full fuel, spares, tools, etc.
But I've never made any real attempt at weight reduction, because don't care that much lol. Budget doesn't support doing an aluminum block engine, and no interest in gutting everything. Hell, I have a small aluminum skidplate sitting here for rally-x and I don't even bother putting that one on, I just run with my heavy steel one :) I don't mind being a tank, my days of thinking I'll be competitive are long over., now it's just for fun.
Next up:
Differential. the limited slip factor really.
I have run through a few rebuilds on the LSD unit in my 4.10 BMW diff(ZF lsd unit from factory) using Whats know as Racing diffs online rebuild kits. From the lovely former eastern block. Some people seem to have good luck with them. Others do not. and ive come to think that i am the latter. The latest iteration I put in because i am having a issue where the initial breakaway of the diff is great. 100+ftlbs. but yet, when it comes to actual acceleration and lets say a simple doughnut/hairpin. All i get is open diff tendencies. One wheel peel and no forward motion. It was like this before last year. and now during last year with this kit. Immediately noticeable on Pavement. But i would assume that I am loosing traction i desire on gravel constantly.
Simply Breakway lock up is great but it seems to do nothing after breakaway.
Here are some of the plates:
Smooth as glass and the friction material they design and manufacture is gone.
Interesting wear marks of only the outside and inside ring? also extremely smooth
Only and Outside ring wear mark. Some of the material is still present inside.
I am curious if these are just not very straight in machining. or that the friction material is just not very good. Possibly just wears out almost immediately?
Stock ZF for reference:
Overall its been confusing trying to get it to work as intended. My current plan is to get as much internal shims, spring washers, and plates as i can as OEM stock supplier. I am running a 3 plate uneven setup as alot of people do. Possibly getting the Pressure ring surfaced although it looks very smooth.
If it continues to not be enough with new OEM plates and the more preload then there is the option of more aggressive ramps. Although there is not really a good budget option for this. Only one coming from the afro mentioned company that I am currently shaky with.
This is the same unit that is in alot of old porsche's so I will be researching what they do also for more reference. Any insight on what i could be missing here would be excellent.
Lets keep this going:
We have been filling time as we gathered parts for the new wiring by fixing the surprisingly rusty tow rig.
A decent job. Hopefully this rig will last a few more years before needing something else. its a great adventure camper also when need be.
Spent some time cleaning up the rear shocks. Some tire rubbing has long since destroyed the helper spring isolators. And it seems we have slightly mushroomed the rear mounts. bearings are still good so we may just have to keep these in until they are really bad.
Next up is actually building the new harness! Very excited to see how it comes out!
I was also able to take a side adventure to attend one rally this year, STPR in PA. Co-driving for friend and rival Dylan Gondyke in his impreza RS.
Always fun to ride right seat. especially in a similarly fast but very different car. We won the rally and our class! No issues besides ripping the wires on my comms and having to yell 2 stages. Hand signals and yelling worked well. Tons of rain the second day but with a decent lead from the first day we cusised home safe in first. STPR is always a great time.
Lots of other notables and GRM regulars taking home trophies also.
Few updates incoming!
Wiring begins!
As in a previous post we are totally redoing the chassis harness for the car. everything from headlights/taillights to windows and wipers. The stock wiring harness has failed me multiple times over the years and it is time to start fresh. Milspec wiring, with duech connectors where possible. Obviously reduce wires and features to my friend Ben's patented "the 14 basic electrical functions of a car"
This will also place fuses and relays inside the car safe from water and dust. as well as give us access to them while strapped in.
Eaton Fuse block and some of the new harness laid across
Ben getting familiar with early 80s german electrical design.
one section completely done. Tail lights. I am being taught proper working techniques as much as we are actually doing on this project
We are also making some changes to the engine harness to change over to drive by wire. This will give me a bit more modern ECU and tuning but still OEM. Overall simpler with just a few more wires.
The OEM fuse and relay organization for the engine loop just doesnt work in this chassis.
Overall it didn't look like we got alot done but nearly all the planning and familiarization with the project was done that weekend. Hopefully another 2 day stint will get it totally laid out and i can pin/wrap everything at my leisure.
Smaller things update.
Appears the ball joint failure at the last race DID have a negative effect on the shock insert of that side. So we will have to get th\his one sent out to be fixed. I decided to send out the rears to get external reservoirs so just another thing to do.
Only other thing we have accomplished is a full rebuild and shine up of the brake calipers.
Final product in BMW M blurple
After that we have not done any updates besides purchasing some items for later. Becoming a new Dad really has kept us away from the car. Rightly SO!
More to come before the new year though.
Funny how kids eat into doing stuff :) I'm lucky that my garage/shop is right outside my family room door (so I could watch the kids and work on the car simultaneously at least).
Quick little project to clean up the ancient Hella buckets and housings :
Just crusty from Rally dirt and some surface rust. All of the adjusters were busted also.
OG
The actual lenses were of various condition. but i felt 3/4 were in very nice condition to continue using.
With some help we located some reproduction 3d Printed adjusters. Come with brass insert also so better than OEM. You can see i have some Amazon LED H1 and H4 bulbs instead of old halogen.
I was looking for something totally different that would fit the e30 headlight spaces. but i could not find much that was around 5.75"(stock) size and be worth the money. I will need another Inner/highbeam lense however as the glass was totally separated and the reflective material was super peeling. 60$ and call it a day to replace that. money would be better spent on more and better light bars. Having a very basic standard road lights can be beneficial in snow, fog, and dust anyways.
Check off another easy at home project.
Got a link to those adjusters? (obviously) mine are pretty much no good at this point either.
Didn't I give you those rusty-ass light buckets? :)
In reply to irish44j (Forum Supporter) :
Nah these came with the car surprisingly.
And yeah ill DM you the adjusters 30$ for 8 is a steal.
Weekend update!
Another big weekend for wiring progress. All circuits and power leads are now setup. remaining harnesses are paired down to only what is needed.
Fuse and relay Plan
some new battery main cables:
Fuse and relay box coming together:
Next visit we will get crimping and finalizing. Get all the circuits tested so it can be properly loomed and wrapped.
Also spend some time repairing some floor holes. In an effort to mount the E-Pedal for ms43 engine management.
Working on finishing up some at home projects including the diff and engine harness cleanup. all to be ready for next time and then we get reassembling!
Been a Bit since an Update!
Work on the car has been few and far between lately but that is going to change for the new year and my recent heightened anxiety of its actually time to resemble this pig.
Some things I have got done:
Finished collecting near all of the parts for the upgrades and changes. Namely Clutch/flywheel and final bits for the Ms43 engine management upgrade. If you are new here i used to run a mismatch of ms42 parts on a 3.0 M54 and its time for that all to die.
Clutch/Flywheel:
Went with a stage 1 SPEC clutch kit. hear good things about them and looks nice in hand. Rated to 311 TQ we should have no issues. Not that I had issues with the stock m20 clutch but we are making sure since we are having the engine run properly now.
Flywheel: We finally decided to retire my 240,000 mile original to the car flywheel that has been through a zillion launches and untold stage miles. Since I don't like the aluminum with steel friction plate lightweight flywheel option we went with this 8.5Lb chrome moly option from redux racing. A nice part that looks well machined and should stand up to some abuse with no wear item parts.
We continued to clean up the engine harness and parts we will be re-using of crap like this:
Differential is completely reassemble. Hoping this time it functions correctly.
A visual of one of the reasons for using the correct management for the engine, MAF sensor comparison:
And some bits installed last time out to start visualizing where everything goes as well as finding out what I misplaced or threw out over a year ago.
Headers:
Clutch Package:
Engine Back in its home first time in a long time: Missing Items mostly bolts....
Should be working on the car more this weekend. Make some more progress with wires, suspension, fuel system changes. And generally closing up more holes while getting rid of things that are clutter. Have to rebuild the exhaust flanges to the rest of the system also.
make sure to fully tighten and loctite the flywheel bolts this time ;)
anyhow, nice progress. I'm under the hood of a different vehicle doing engine stuff, but need to get the e30 up and running again eventually....
Havent posted in nearly 2 months!
Lots of progress and updates.
New control arms and tie rods:
Before
After
Rear brakes on and all new brake hard/soft lines:
old icky ones
New braided bendy ones
Relocated the bias adjuster to place i can actually use it. (bracket not pictured) Will be nice to actually attempt to play with this during or between stages.
Diff and Axles are back in. Really now we have committed and the whole driveline is in. We had to measure the new headers and see if the exhaust could fit and be made.
Had the engine out to do the measuring:
a Redy to go M54b30 weighssss! (with alternator, intake, TB, LW flywheel/clutch and headers on it.
Pretty big. but being fully aluminum it is still lighter than the iron block earlier engines and the original m20.
We wanted to put in a new steering coupler for new ujoints as they were clicky. and the rubber damper was coming apart at the seams.
Unfortunately the after market recreation of these didnt even last instillation and we realized the centering pin was broken and very wobbly. Fortunately they gave me a refund and we are waiting on a good condition original one.
Id like to get rid of this mess somehow someday but need to retain the strength and the collapsibility of it. this is really the only part of the system that collapses in a crash.
Got a quick realease though! never had one before! should make getting in and out of the car much easier for me and crew that is taller than myself
Started work on a new center stack as we are ditching nearly all the stock dash controls.
Placement
Beginning of the layout. leaving room for gauges and other buttons
Wiring magic continues and the car is starting to come alive!
Wiper and blinker functionality remains stock including the OEM wiper relay to retain intermittent wipers and parking.
Mounted just near the steering colum
Blinker relay and hazard witch is nearly 100% oem harness as it is divorced from the old chassis harness. just have to feed it power and run the outputs to the new harness.
Exhaust was a tight fit with the new headers but looks great!
various colors will all become rally tan soon enough.
A surpize window motor rehab project as these like to gum up and even rust inside the case:
Little scraping and new grease was all good.
Endless floor patching is also finally complete!
Overall major projects are the focus but the little things are cruising along. Fuel cell filler V3 is on hold until more funds come in. Those parts are needlessly expensive. Next up in wiring is getting the chassis harness to play with the engine harness. Possible even start it the next session we do of that. Once it is all done we will still have to putt it all back out and wrap it up properly as well as terminate many connections.
Still waiting on suspension parts and for the one front insert to be repaired. being able to roll the car around would be nice soon.
Going to have to keep up the momentum as we are hopeful for the first event back, a rally sprint, on May 4th. great way to test everything out. Still need to put serious street miles on it and hopefully a dyno session to make everything excellent!
