1 2 3 4 5
RacingComputers
RacingComputers GRM+ Memberand HalfDork
6/3/24 6:51 a.m.
RacingComputers
6/3/24 6:56 a.m.
The A/C condensor lines presented a challenge, however, the challenge has been overcome.
Final body work is being addressed
Shooting to make Track Night at Charlote on the 26th of June
Details / updates to follow
RacingComputers
6/3/24 1:00 p.m.
Brake Hoses Installed and routed
RacingComputers
6/3/24 1:02 p.m.
Will validate clearance challenges with new Wheels and tires on on the ground
RacingComputers
6/5/24 10:40 a.m.
Front Brembo 6 pot calipers successfully bled after the installation of revised chassis mount front braided brake lines
RacingComputers
6/12/24 3:49 p.m.
SVE Front Heavy Duty Front Hubs  complete with ARP studs, seem to have increased in size.  14M x 1.5 vs stock 1/2 x 20.
Looking for opened ended lug nuts.
And so the search journey continues.
RacingComputers
6/15/24 6:27 p.m.
Rear Side Window scoops mounted
RacingComputers
6/20/24 12:38 p.m.
Front and Rear Bumper covers Painted.
Installation and striping is next on the list
Note the brake Ducts mounted and ready for hoses to be added
RacingComputers
6/20/24 12:40 p.m.
Rear Bumper Cover all set for installation.
Good Shot of the Watson Racing Rear Tow Hook Mount installed
Indy - Guy
Indy - Guy UltimaDork
6/20/24 1:30 p.m.
In reply to RacingComputers :
That rear tow hook set-up looks pretty sweet. Could it actually hide behind the license plate (if plate was mounted)?
RacingComputers
6/21/24 10:37 a.m.
That is indeed the plan.  Plate mount will be set up with Duze fasteners, so that it can be un-installed at the track, tow hook installed.
Remove tow hook after the event, re-mount license plate, drive home.
Area on the inside of the rear bumper cover, where the plate will mount, has been fortified with a composite material to strengthen the area.
Picture to follow
RacingComputers
6/29/24 10:52 p.m.
Getting closer to being BACK Together
RacingComputers
7/2/24 5:22 p.m.
Rear Louvers Mounted
RacingComputers
7/2/24 5:29 p.m.
Ran into a small challenge getting the Driver's Side O2 replaced
RacingComputers
7/2/24 5:30 p.m.
RacingComputers
7/2/24 5:32 p.m.
On the HUNT for a 18 x 1.5 Tap
Have a thread chaser but not a real tap.
The adventures continue
RacingComputers
7/15/24 1:57 p.m.
Left Front O2 sensor almost impossible to access without removing transmission mount and rasing the motor.
Decided to move the bung 6 "  still up stream from the converter and is approximately the same location as the one on the passenger side.
RacingComputers
7/15/24 4:36 p.m.
New bung Installed for LF Upstream O2 sensor:
RacingComputers
7/19/24 8:08 a.m.
Repair to XP Pipe and O2 Bungs is completed.  4 New Bosch O2 Sensors installed and connected.
Drawtite Trailer Hitch installed, bolted and welded.
Watson Rear Tow bar reinstalled
American Thunder Axle Back mufflers reinstalled
Nose, tail & Hood on the agenda
On the Ground by this time next week.
RacingComputers
7/19/24 5:54 p.m.
Rear Bumper Cover with Stiped Mounted
Rear Body Work Completed
Front is forthcoming
RacingComputers
7/24/24 12:53 p.m.
Now you See IT
RacingComputers
7/24/24 12:54 p.m.
NOW YOU DON'T
Indy - Guy
7/24/24 3:53 p.m.
That turned out nice!
Also, we're going to need more info on the Camaro over on the side"
RacingComputers
7/24/24 4:00 p.m.
LS 1    Tremec 6 Speed Swap
Details to follow
RacingComputers
7/25/24 4:46 p.m.
Hood and Nose Mounted
1 2 3 4 5
fhsDQHZRJrEYNZKSCcJW0ta55Br1JF7P8FDvT9iyr3bPs92cM2WXmeCNqZSpVRbq
