1 ... 7 8 9 10 11 ... 17
mazdeuce - Seth
mazdeuce - Seth Mod Squad
9/22/19 7:27 p.m.
That there is a classy get together.
Indy-Guy
Indy-Guy PowerDork
9/22/19 8:34 p.m.
I just got this emailed to me.....
AxeHealey
AxeHealey GRM+ Memberand HalfDork
9/23/19 8:28 a.m.
I'm in for Jag Leaper Special or John Leaper Special.
Super dig the marker light as the eye!
Indy-Guy
Indy-Guy PowerDork
9/27/19 10:49 p.m.
I've been chasing a worsening front end vibration and a wheel bearing going out: so this is happening.....
At work tomorrow I'll press the new bearings in.   I also did an oil change while I was at it.  Transmission fluid drain and fill is planned as well.
Indy-Guy
Indy-Guy PowerDork
10/5/19 8:23 p.m.
Took the spindles into work last Saturday.  It was a real pain in the rear.
Super long cheater bar with a 2 inch 12 point socket clamped onto the spindle nut/ABS ring.  It finally let loose.  We got the old bearings pressed out fairly easily but the inner bearing race was seized on both spindles.
Tried welding a pair of flanges onto it, then went to press on the tabs.  Just broke off, I think it was too oily to get good penetration.
So we put it in the lathe and tried cutting it off....
Finally just got out the death wheel and made several cross cuts and used a chisel to work it off.
Then new bearings went in easy.
After all that, I discovered a loose lower ball joint, So I had to replace that while I was in here:
Indy-Guy
Indy-Guy PowerDork
10/5/19 8:30 p.m.
Then I decided to do some minor performance mod: add a bit of lightness.
Old battery weighs in at 46 pounds.
new (smaller)  battery weighs in at 15 pounds:
Comparison:
Patrick
10/5/19 8:32 p.m.
$17 rural king tractor battery?
Indy-Guy
Indy-Guy PowerDork
10/5/19 8:39 p.m.
In reply to Patrick :
Yes.  Rural King lawn tractor cheapo.  I do believe you're the one who pointed me in that direction.  Thanks for the tip. yes
(Now I'm down to 4270 with driver)   wink
Ranger50
Ranger50 UltimaDork
10/5/19 8:56 p.m.
Indy-Guy said:
After seeing the above pic, I know you're probably thinking "Indy, what the Berk are you doing with Mercedes Benz parts, I thought this was a Jag?"
And you would be correct. However, Jag-you-are used a Mercedes Benz 722.6 transmission in the XJR and I wanted to keep it as OEM as possible. More $$$ for sure, but I don't want to risk my car with cheap Chinese knockoff parts.
Damn, I just saw this thread and you could have used DCX 300/Charger parts, same MB parts.
Indy-Guy
Indy-Guy PowerDork
10/5/19 9:08 p.m.
In reply to Ranger50 :
Thanks for the tip.  I did a fluid drain and fill on the trans today, just as a preventative measure, because I plan on beating on it pretty hard in the burn out box of the drags in a few weeks.
I'd eventually like to tighten up the shifts on the trans, it delays in between gears a bit too much for my tastes (although I'm certain it was designed that way for the discerning British gentleman for a smooth ride)
Ranger50
Ranger50 UltimaDork
10/5/19 9:17 p.m.
In reply to Indy-Guy :
Stock programming sucks. The trans itself can handle tons of abuse, if it doesn't leak all its fluid out. Lol
Indy-Guy
Indy-Guy PowerDork
10/13/19 5:08 p.m.
Trying out version 3.0 taking the sponsor panel into consideration. Also, I think the green is dead.  Substituted with silver.
Actual number is probably going to be 44.
I tried this version (3.1) but don't think Tom will allow it because it's behind the rear wheel.
yupididit
yupididit GRM+ Memberand UberDork
10/13/19 5:13 p.m.
Dad jeans
Patrick
10/13/19 5:25 p.m.
In reply to yupididit :
I'm very glad I bought a Mercedes after your observation
Billy_Bottle_Caps
Billy_Bottle_Caps SuperDork
10/13/19 6:16 p.m.
This is awesome! That is all
aselmike
aselmike New Reader
10/13/19 9:16 p.m.
That vinyl is going to be sick
Indy-Guy
Indy-Guy PowerDork
10/14/19 5:57 a.m.
In reply to Billy_Bottle_Caps & aselmike:
Thanks, I'm just having fun with this.
In reply to Stampie:
This is the proper way to Polish a Turd:
Patrick
10/14/19 7:09 a.m.
So.  Many.  Minions.
Indy-Guy
Indy-Guy PowerDork
10/14/19 1:53 p.m.
Patrick said:
So.  Many.  Minions.
Yep,  I've always got help in the garage:  The kids LOVE dad's Jaaaag!
Georges1991
Georges1991 New Reader
10/14/19 2:04 p.m.
Look at all that free labor!
I mean lovely children
Indy-Guy
Indy-Guy PowerDork
10/15/19 7:07 p.m.
I went to do some engine bay cleaning and found this under the hood tonight:
And..... Since I'm going to need that supercharger to kick Stampie's ass, I better get a new belt on there.
Stampie
Stampie GRM+ Memberand UltimaDork
10/15/19 7:13 p.m.
You need more than that.
Indy-Guy
Indy-Guy PowerDork
10/15/19 7:15 p.m.
In reply to Stampie :
I saw all that junk in your trunk.
Not worried
Robbie
Robbie GRM+ Memberand UltimaDork
10/15/19 9:39 p.m.
Aaaaaaah! That's like almost the exact same thing that happened to mine this winter with the belts.
Check all the idler pulleys and bearings stat
Indy-Guy
Indy-Guy PowerDork
10/16/19 10:19 a.m.
Thanks for the heads up.  I went ahead and ordered the SC tensioner and idler pulleys so I can have them on hand in case they're bad when I get to it this weekend.  Not a lot of room (time wise) for error.  We depart for Gainseville in 7 days!
bfVGUWDcCHLtvAldf6p1KJnEQEDzYlG6e7nLjPlEOAPUlItd8iOkMFl000Jtuots
