So went to pick up my bearings from part store...... ordered a full bearings set, they gave me a single set of rod bearings..... woooo. Back to rockauto I go
Got my bolt to bolt intake manifold on, so got that done, along with oil drain back on.
Did some cussing and fighting with 02 sensor but it came.
and the official tool of any northern car. There ain't a single hole in this car that hadn't been chased with a tap.
Currently on a kitten break
On the wait for bearings and bottom end can start going back together.
What are you using in the cleaner? I just used isopropyl alcohol in the past for some TBI injectors, but figure there has to be something better.
That kitten is tiny! Also very cute!
Calico's are female, so what's her name?
Got my injectors in, no fuel leak. Still have issues. When are you putting yours back in?
Bent-Valve (FS) said:That kitten is tiny! Also very cute!
Got 4
Mask, gloves, stonks, and plague doctor.
Mine go back in once another set of strainers arrive.
Head is ready to drop on.
Pistons cleaned up and ready for rings when mains arrive. Was a pleasant surprise to find the good factory pistons in it.
New trailer lights that are serviceable/rebuildable, new wiring and new bungie cords color coded by the children.
Hint: the reason it's out is orange and black
On its way to garage
On stand ready for depression
Hint 2: F
So we have a solid case of death by Fram.
Measured rod journals, and they were egg shape and have some scoring, along with the mains.
The pickup was full of fiber and some metal.
Took the filter and cut it apart and guess what..... It's missing pleats.
Will post some more damage later.
Ol frammy boi killed the motor, this is the oil pump.
crank is at machine shop getting polished
Motor is stripped, walls measured, honed, and re measured to make sure they are even and not egg shaped.
Piston to wall clearance has been measured, it's a touch on the loose side, but just gonna do it. Ain't scared ..... Rings are gapped and cleaned up, piston and rods are cleaned and ready to go in.
Lower water neck, block, oil pan (full of fiber and goo), and valve cover all got a date with a power washer.
E36 M3 work in progress.... Cleaning.
Inbound to the car wash, 2.2 block, oil pan, valve cover, 1952 Kohler block and oil pan in tow.
Old man goes "how many people are driving a swapped neon, towing a trailer with a 2.2 on a engine stand in it and a 70 year old kohler motor"
2 cans of degreaser and getting soaked, it look decent.
wheelsmithy (Joe-with-an-L) said:Professor_Brap (Forum Supporter) said:
Tractor.
TO-30, most useful thing ever.
on a scale of 1-10 how mad will this make the hard core Mopar boys
Color reference for future use.
Oil pan and it's color
Everything is ready for reassembling, minus a oil pump and distributor seal.
Block and oil pan painted
Broken bolts in distributor fixed and re tapped and cleaned
Rods cleaned and checked bolts for stretch
ARP head studs installed and ready.
The last part I was questioning was bad, was confirmed bad.... Oil pump.
So pulled the pickup off, started to run parts wahser fluid backwards through it..... Fiber and some small wire wad coming out of it. Popped the top on the oil pump and this is our find.
Note the deep imprints from wire. This will come in later.
Side #1
Side #2
Side #3
side #4
This is the oil pump body, it is destroyed.
Pulled the "sheild" off pickup and it was packed full of filter material and when that was pulled off 10ish strands of wire where missing off the pickup screen..... I think I know where those went.
