Alright, I've been distracted by the 986 project but as we had an early snowpocalypse it's time to finish the winter beater. I've been putting off doing the mechanical work because that isn't much fun when it's below freezing in the garage.
First order of business, clear the snow off the car and chip away enough ice to be able to find the lift points again (have I mentioned I hate winter in MI?)
This is the ice chipped away to reveal a single lift pad:
It's the Boxter's turn to turn into a snow mound:
Winter wrenching is the worst. Took about an hour to get to this point:
Ok, first order of business was to fix the right rear suspension. The wheel had some dynamically variable toe. Like a lot. The ball joint on what BMW calls the guiding link had failed. It's actually fairly simple to replace...just mark the position of the eccentric bolt, remove the arm, and replace. Of course I overcomplicated things by shearing the bolt. BMW dealership had one in stock locally (seems common enough to break them) but that set me back a day and $10.
Reinstall and pay attention to torque specs this time. Now, onto more difficult things.
Everything else on that corner seemed to be working but the boots for the lower ball joint and sway bar end link were cracked. The ball joint was a little more involved but not too bad.
You basically just unbolt everything and let the control arm hang:
Now you have good access to the ball joint. This one came out with just a basic ball joint tool and a mini sledge:
Press the new one in:
...and wrestle with a bunch of different suspension mounting points to reassemble. Replacing the integral link (pictured below) is a no-brainer as a quality Lemforder unit is uber cheap. You can also see how bad the end link was:
I also ended up replacing the LH guiding link and all other end links because the boots looked worn.
Next order of business was the brakes. The pads looked new-ish, rotors were good, but all four hoses looked pretty awful:
This was easy enough. Basically soak everything in penetrating oil and carefully remove the old hoses. I always find new brake hoses to be a satisfying job (though messy)
My awesome wife then assisted me in bleeding the brakes...it was around 10 pm and below freezing at that point. She's the best...but I may be getting a power bleeder for Christmas.
The fluid was super nasty; it was nearly black and definitely had some water contamination. A bottle or two of brake fluid later things looked great on all four corners.
So what now?
I'm not sure. On it's current tires and open diff, this car is terrible on the ice. I think I will register it and maybe put some cheap used snow tires on if I can find some. Although, this morning on the freeway I saw somebody ripping around in a Boxter and I now want that in my life. This car may get sold to make way for the 986 so if you happen to be interested in a fairly solid manual E39, let me know!
