If you do have to drill it sometimes burning it is safer. Torch on the drill bit then let it melt it's way. If you have to cut it a wood blade backwards does the trick.
In reply to maschinenbau (I live here) :
I'll be able to come help for tonight at the very least! Sounds like a lot of fun
maschinenbau (I live here) said:In reply to TVR Scott (Forum Supporter) :
Crap, you're right. I accidentally ordered acrylic. NHRA doesn't specify the type of plastic. This stuff is 3/16" thick though and I'll have a full-face helmet on. I think it will be fine.
Worst case and it totally blows apart on you, HD or Lowes usually have sheets of 1/16" polycarb.
TVR Scott (Forum Supporter) said:Make sure you gently massage out those little dings in the back fender.
with a berkeleying sawzall
Patrick (Forum Supporter) said:TVR Scott (Forum Supporter) said:Make sure you gently massage out those little dings in the back fender.
I'll up the ante. Use a claw-hammer.
This will be even more glorious if you keep only the front doors and take a chunk out of the middle:
Paul and his son stopped by to help tonight. Together we got pretty far! Paul seemed veryeager to do damage to this car. I think he got his fill, but only after smashing the rear window and taking the first plunge into the roof with a sawzall.
This is the first draft of the no-roof situation. Will probably go further than this tomorrow. Also not sure about having a decklid or not. First step in the morning is seat mounts, then roll bar fab. The rest of the plan will fall into place.
The suspension sits ALOT higher now, especially in the back. This is good news.
SVreX (Forum Supporter) said:Suns up! Where are the daylight pics??
Checking in from home with great interest. Looks like a fun time. I wish I could be there too. No, I will not be attending this year.
