1 ... 15 16 17 18 19 ... 113
4cylndrfury
4cylndrfury SuperDork
10/28/11 7:57 a.m.
I still giggle in delight when I look at your suspension setup.
loosecannon
loosecannon Reader
11/1/11 7:56 p.m.
It turns out that my aluminum floor is not legal for the class because the rear tranny crossmember bolts to it and becomes load bearing, and aluminum is not allowed for load bearing structure. I simply added 1"x2" steel tube between the transmission crossmember and the frame rails and the problem is solved.
unevolved
unevolved Dork
11/3/11 4:51 p.m.
Just checking in. I'm one of the many, many people who watch every update with awe and jealousy, but may not say anything. We're here reading this, and thanks for posting.
tuna55
tuna55 SuperDork
11/3/11 8:07 p.m.
unevolved wrote: Just checking in. I'm one of the many, many people who watch every update with awe and jealousy, but may not say anything. We're here reading this, and thanks for posting.
Ditto, my friend.
turboswede
turboswede GRM+ Memberand SuperDork
11/3/11 9:07 p.m.
You know you could visit his blog as well. Maybe he's posted something there.
loosecannon
loosecannon Reader
11/3/11 9:59 p.m.
I am still getting things done on the car. Just today I built a drivers side seat mount, remote oil filter mount, radiator overflow mount, top radiator shroud/hood pin holder, wired the fuel pump and bled the brakes. Because of the reduced weight of the v8, the car sits 1.5" higher in the front. I'm debating if I should just lower it with the pushrods or do I need to adjust the wheel rate.
nocones
nocones GRM+ Memberand HalfDork
11/3/11 11:15 p.m.
If it wasn't particularly sorted or running at a Known handling sweetspot (read perfect front rear wheel frequencies) I would just shorten the pushrods and see how it is. You can always go back to try different springrates in the future but this way you don't have to rebuild bellcranks.
loosecannon
loosecannon Reader
11/12/11 6:40 a.m.
I drove the car around the kart track for a few laps, it was too much fun! It feels understeery so I have to give it some welli to get it to rotate but otherwise the handling feels good. It does smoke a lot but I hope to have that problem solved soon. Here is video from 3 different angles: http://www.youtube.com/watch?v=67hQlqxbzHo
http://www.youtube.com/watch?v=wD9xiu4WV1M
http://www.youtube.com/watch?v=Y1ms9A3S7IU
JoeyM
JoeyM GRM+ Memberand SuperDork
11/12/11 7:42 a.m.
looks fun
nocones
11/12/11 8:12 p.m.
The drift from 15-23 seconds in the first video is most impressive
unevolved
unevolved Dork
11/13/11 8:31 a.m.
That's awesome.
loosecannon
loosecannon Reader
11/14/11 10:41 p.m.
Because the floor and side pipes dropped 3 inches, there was an ugly gap between the body and the pipes so today I took some 18 gauge aluminum and filled the gap. I was going to paint it but some have the opinion that it looks good in natural aluminum. It could also be a good place for sponsor stickers.
unevolved
unevolved Dork
11/14/11 11:28 p.m.
Looks good.
I've watched that first video three or four times and posted it on Facebook. There's something inherently awesome about an open-pipe V8 sliding around indoors.
Timeormoney
Timeormoney Reader
11/15/11 5:12 p.m.
Awesome awesome awesome awesome awesome awesome
friedgreencorrado
friedgreencorrado SuperDork
11/15/11 6:08 p.m.
loosecannon wrote: I drove the car around the kart track for a few laps, it was too much fun! It feels understeery so I have to give it some welli to get it to rotate but otherwise the handling feels good. It does smoke a lot but I hope to have that problem solved soon. Here is video from 3 different angles: http://www.youtube.com/watch?v=67hQlqxbzHo http://www.youtube.com/watch?v=wD9xiu4WV1M http://www.youtube.com/watch?v=Y1ms9A3S7IU
Fantastic videos! I was about to just say "INDOORS?!?!"..but then I remembered you own the place.
loosecannon
loosecannon Reader
11/16/11 2:09 p.m.
It's a perk of owning a kart track ;) I finally built the passenger rear fender flare. I planned on doing front ones as well but am not sold on the flares yet. Do you think I should get rid of them, paint them or leave them and build front ones, too?
4cylndrfury
11/16/11 2:12 p.m.
looks great...Hell yeah Id add some to the front too!
...Then again Im not the one going to spend the time to line everything up and do the fab work, so consider the source when reading this
MG_Bryan
MG_Bryan Reader
11/16/11 2:14 p.m.
I'm not much of fan of the flares, but that's just me. That car is bad ass and now I really want to find a location that will let me drive a car indoors.
unevolved
unevolved Dork
11/16/11 3:45 p.m.
I like them, but I think they should be painted. I think eventually too much bare aluminum moves from "accent" to "incomplete."
loosecannon
loosecannon Reader
11/19/11 11:34 a.m.
I have removed the flares and will save my pennies to get this body kit:
ValuePack
ValuePack Dork
11/19/11 12:06 p.m.
1st vid is a great overview of just how well that car fits on track. 3rd is great fun, all kinds of awesome V8 burbles and slip angles. I'm still digging his car.
Kendall_Jones
Kendall_Jones Reader
11/19/11 1:04 p.m.
if that's the spridgetech kit, I can probably get you a deal :)
Kendall
loosecannon
loosecannon Reader
11/19/11 1:10 p.m.
Kendall_Jones wrote: if that's the spridgetech kit, I can probably get you a deal :) Kendall
Yeh, it's the Spridgetech kit-what kind of deal?
SkinnyG
SkinnyG HalfDork
11/19/11 7:44 p.m.
loosecannon wrote: I have removed the flares and will save my pennies to get this body kit:
That car is relatively local to me. I know the guys that run it, they run our local hill every May long weekend.
This is their "old" car:
loosecannon
loosecannon Reader
11/21/11 3:08 p.m.
If you go back to the post where I weighed the car with the V12, you will see that the total weight (with me in it) was 2353 lbs and 46.8% of that was on the back tires. Now, with the V8, the total weight is 2136 and 51.1% of that is on the back tires-this is all good news. All I need is to switch to aluminum heads and rear diff and some glass fenders and I'm down to the class minimum weight. :)
HaWl04fN9sOLB5m1VAGBfvTIQ1sfbAMgg5oYPqcOH8bqTz5ZIQ3753vJ226gDJUC
