I have had a couple of instances of problems with 338 where I should have known better - bad base timing, worn out plugs, etc. The cobbler's children and all that. So I decided to do a bit of actual maintenance.
First was a brake fluid flush. It's been looking darker than I like and while I have changed the front pads, I suspect I neglected that. So some nice clear DOT 4. I did discover that the left rear caliper has a different bleeder screw from the others and it was clogged. I have a spare caliper on the shelf but it had a different bleeder screw again. So I removed the non-original one, cleaned it out and I'll keep my eyes open for a factory replacement in the FM salvage parts bin.
I also found out where my occasional wheel rub was coming from with the new tires. Nothing too serious, the plastic will self-clearance and I gave myself a little extra clearance on the sheetmetal with some percussive persuasion. I think the problem is another slipped upper mount - I've been simply reusing old ones that are better than the ones I've removed. I have a set of four new ones waiting to go on, I think that's moved up the priority list. That bumpstop isn't one I usually use on the front either, so I'll make sure that's updated at the same time.
I also moved to a smaller lug nut. The factory 21mm ones were a tight fit in the new wheel, requiring the use of a thin wall socket. The new ones (which I think used to be used on the Targa Miata) let me use a 17. Much better. The only downside is that now I have to pay attention to the correct clocking of the hubcaps as they have a relief for the lug nuts that wasn't needed for the factory ones.
Next was some new Redline MT-90 fluid for the transmission and some 75-90 for the rear diff. The latter is a tiny little thing, the smooth case design that was only used in the earliest cars. This was easy enough. Looks like I'm due for an oil change as well, which means I'm actually driving the car! Good news there.
Since I knew I'd be pulling the shifter to change/replenish the turret fluid, I decided to pick up a shifter rebuild kit from my local Miata shop. I knew the upper boot was probably damaged and there was a good chance the lower was as well. The insulation is usually pretty ragged so I also picked up an upgrade from the shop. The big upper boot is an aftermarket one (guess where I got it?) that is made of thicker rubber and should last longer.
Overall, the shift feel is pretty good on the car, I have no complaints. But when I fished the parts out, I discovered that some of them were definitely past their prime.
It took me a while to find the broken chunk of the wave washer after it fell down into the turret, but thankfully that's separate from the body of the transmission and it had not traveled far. There's also a washer missing compared to the parts diagram. The new bushing on the bottom of the shifter was a tighter fit so I suspect I've managed to generally rid myself of some slop.
I also had a bolt break off, one of the four for the upper boot. The bottom of those are exposed to the elements so this is not unusual. I suspect the usual solution is to just use the remaining three. In this case, I drilled out the broken piece, retapped and felt good about myself.
Here's the new insulation. I'm curious about how inflated the shift boot will look.
No chance to drive it yet, as I'm waiting for a package that I want to install before reassembling the interior. So I don't know if the feel has changed.
