I fell down a YouTube rabbit hole last night and now have a new item for my Christmas wishlist: Instructions to build your very own real, running engine from scratch:
https://www.hemingwaykits.com/category-84
Has anybody ever seen these before? I feel like I've been missing out on an even crazier little corner of the world than ours.
I haven't seen that particular engine before but scale model engine building is indeed a fascinating corner of the world. It's also one that I've been deliberately trying to avoid exploring too much lest I fall down an expensive and time consuming rabbit hole.
Tom1200
PowerDork
11/13/23 4:07 p.m.
In reply to Tom Suddard :
Look up a guy named Alan Millyard; he does wild stuff like building V12s by combing two Kawasaki KZ1300 motors and making 4 cylinder two strokes using a Kawasaki triple.
ShawnG
MegaDork
11/13/23 4:10 p.m.
If you haven't heard of John Britten, you should do some googling.
stroker
PowerDork
11/13/23 4:38 p.m.
I'd love to build a V-4 500cc two stroke motorcycle engine... Just pop the cylinder/architecture off a 250cc motocross bike. All you'd have to build is the crankcase/crankshaft and then CNC the crankcase to include a compatible gearbox...
I really want to build one of those small engines and put it in an RC car.
While an RC truck or drifter sounds fun, I don't know if there is anyway where to use them locally. Bashing around by yourself tends to get boring pretty quickly.
I wonder if that would be any narrower than an inline 4. Since the crankcase is part of the intake path you couldn't share crank throws or crankcase sections and by the time you add the required crankcase webbing, seals and crank throws there's likely to be no benefit to the V shape. Except for what I suspect would be an awesome sound!
Driven5
PowerDork
11/13/23 4:59 p.m.
I still can't see putting the time and effort into building a working 'model' engine, when I could just build it big enough to be a 'real' engine instead. But if that's your thing, you might want to check this place out:
https://www.homemodelenginemachinist.com/
For a full-scale 'build your own engine from scratch' rabbit hole, check out the YouTube channel documenting the work of Pete Aardema and Kevin Braun with their home-built LSR engines:
https://www.youtube.com/@GregQuirin/videos
stroker
PowerDork
11/13/23 5:50 p.m.
Kenny Roberts had the freedom to do whatever he wanted with the Proton design, which was the last "factory" 2 stroke in MotoGP. They went with a V-3. Yamaha left the TZ750 (inline 4) and went to a V4. Suzuki had the Square 4 and Honda had a V-3 before Proton did. All this is memory so don't hold me to it.
Guy named Foucault (I think) does something similar for some weird rally-like class in France where they have a 2 liter naturally aspirated limit. So he makes crankcases to combine 660cc motorcycle heads with three or four banks, and puts them in a 205 T16. 450hp from a 12 or 16 cylinder 2 liter engine. They sound like dentist drills.
My wife's grandfather built 2 different working miniature steam engines from scratch. Each was mounted on a dime. Supposedly, one is in the Smithsonian's collection.
NOHOME
MegaDork
11/13/23 7:24 p.m.
Was thinking more along the lines of a big metal billet and your milling machine. I thing there is a guy called Steve Morrison who does this with LS style engines and goes very fast down the quarter mile.
Mercury Marine did it just fine with V6 engines. The cylinders were closed off at the bottom and the rod just went through a little slot. Exhaust scavenging did the rest.
A 2 stroke is the only way to have an even firing 60 degree V6 with shared crank throws, and it appears that MM did use shared crank throws and had a little full-circle divider between the rods, which only adds a small amount of length to the engine. 60 degree 4 stroke V6s have cranks that look a lot like 4 main inline six cranks, these are even shorter.
I was really hoping you all would say "no no that's a terrible idea don't do it!"
You must be new here.......we never say don't do it.
Agreed.. It's significantly more likely to be "No, no, that's a terrible idea. When do we start?"
My dad went to high school with a kid who built a working rotary engine in the schools machine shop. He'd be old now, but I always wondered what the career arc would be of someone so talented so early.
sotaro
New Reader
3/26/25 1:54 a.m.
I am thinking a supercharged V-4 two stroke composed of two Bombardier Skidoo E-TEC 800 or 850 cc barrels, pistons and heads with two ecus would be the cats meow. Two by 165 hp = 330 hp. Developing a crankcase that will have space for the intake/transfer tract supplied by the supercharger/turbocharger would be a challenge. Otherwise, the crankcase would be a normal V-4 with 3 plain main bearings and common rod journals, a high pressure oil pump, and either wet or dry sump. No crankcase compression. Expansion chambers would be useful. 180 degree crank. I cannot find the bore pitch on the ETEC, but it must be substantial. The bore itself is 82mm and the stroke is 80.4mm.
While just a fantasy, this engine would be very interesting with relatively good fuel and oil consumption for a two stroke and very powerful for its weight and very small size.
The working v8 models look really cool, but then I look at the price and realize that it is better spent on my 1:1 v8 instead.
Trent
UltimaDork
3/26/25 10:09 a.m.
I have loved watching this guy build Briggs and Stratton based V8 and radial engines
My wife and I visited a friend in New Zealand back in 2011. We went to a random museum mostly of natural history stuff then rounded a corner and there was a Britten V1000 on a stand. I must have spent a half hour poring over the thing. It was amazing.
I don't think building a kit qualifies as "from scratch." From scratch would entail casting your own pistons from recycled beer cans.
A clever guy in the Netherlands is building bottom ends that you cap with two KTM cylinder assemblies to net 587cc. He'll sell you the crank too (also KTM parts). It comes with mounts to fit an Aprilia RSV1000R ('04-'09?) and also accepts the gears from that bike. His prototype weighs about 300lbs and he's seen 150hp on the dyno (the screenshot said 'corrected' so 130 at the wheel?).
I've been hot on the Bimota V-Due (Bimota's 500cc v-twin 2-smoker from '97) for quite a while but this may have surpassed it in the Want It department. The shop tuning my Aprilia Cup has a bottom end in hand and will be building it up. Back of the envelope, I think you can build a very nice bike for around $20k all-in (clean used RSV, bottom end, KTM parts, etc). I'd have an order in but certain, um, government actions have made my job security feel pretty sketchy.
https://www.youtube.com/watch?v=uvj5Mt1gJ2I
