JThw8
JThw8 PowerDork
5/6/14 1:19 p.m.
SlickDizzy wrote: Up here in the rust belt, weird stuff holds value a lot better, too; it's tough to get into an old MG or Fiat that isn't terminally rusty for less than $3k. Same goes for Miatas, MR2s, etc. Like, check this out. Comes with a hardtop and everything, I bet I could throw the dude $1500 and take it home. http://rockford.craigslist.org/cto/4452397268.html
This is a car I generally find to be more fun the less you spend and would make <$1000 my goal. But if you could get into that one for $1500 I'd do it assuming it's as decent as it looks.
shelbyz
shelbyz New Reader
5/6/14 3:15 p.m.
Because they offer some cheap turbo fun, I've looked into these. I asked about them on here a couple months back and didn't get much.
While I'd love a Miata, in my area my price range seems to only turn up early beat B6 PILES. For what those piles command, I've found MINT Capri XR-2's.
While they don't offer the same virtues as the Miata, I'd be looking at mostly 99% drop top fun and putzing around town and about 1% Miata stuff...
Check out teamcapri.net as it seems to be the only forum for these things. The admin there can tweak the stock ECU to run more boost for a small fee if you send it his way.
I've never owned one, but here are some things I've learned:
-1991 cars suffer from the same crank issues that early B6 Miatas suffer from. It was cleared up for 92-94 cars.
-1994 cars have better suspension parts, but are pretty hard to find
-The aftermarket is scant. As some have mentioned here, some nice suspension upgrades can still be had. There was some overlap with the 323 GT/GTX aftermarket, but most places that offered 323 stuff (like Corksport and Racing Beat etc. haven't for years now.) Aftermarket camshafts from a B6 Miata will bolt in. Kelford apparently makes a nice set in various sizes.
-There is some compatability with other vehicles. The stock IHI VJ14 turbo is related to other Mazda VJ turbo's of the era. Popular in the 1G F2T Probe/MX6 world, the VJ14 can be "hybridized". While keeping the VJ14 hotside, the compressor wheel and housing can be swapped with that from a Probe/MX6 VJ11 or that from a turbo from a 87-88 T-bird turbo coupe. Using the T-bird stuff on the Probes usually gives them a nice boost, so I can only imagine the same for the lighter B6T cars.
-You'd have to dig on Teamcapri, but IIRC the exhaust mani bolt pattern is almost identical to that of a D-series Honda. A cheap way to upgrade to a non-IHI turbo is to slightly modify the flange of an eBay D-series turbo mani.
That's all I can remember right now.
There was a guy on that board with an XR2 that put the B6T top end on a B6 bottom end for higher compression. Then, he somehow fabbed in a DSM 16G, added an FMIC, and I think some fuel mods. The car apparently ran high 12's spinning and torque steering, but was still decent enough for DD duty.
ScreaminE
ScreaminE Reader
5/7/14 11:12 a.m.
http://greenville.craigslist.org/cto/4422677083.html
Seems like the way to go.
MadScientistMatt
MadScientistMatt UberDork
5/7/14 12:20 p.m.
Its main problem is that Miatas exist and are not much more expensive. Think of it as a turbo Escort / Protege convertible and you'd be pretty close. I'm not sure if it is based on the BF or BG platform.
racerdave600
racerdave600 Dork
5/7/14 3:38 p.m.
They were true competitors on the showroom floor when new. If the Miata had not come out I think the Capri would have enjoyed more success. At the time, they were about your only choice for 2 seat convertibles, aside from the aging Alfa Spider.
ScreaminE
ScreaminE Reader
7/31/14 11:48 a.m.
I still kinda want one
http://detroit.craigslist.org/okl/cto/4579859894.html
b7M0WWq7g1eq4P7fOsYsv24kS7p2LBa2NByPRG925NWtSWvGFG2m1EpYYYME8PIL
