Knurled. said:"Technically legal" is the key - most sanctioning bodies require the cages to be welded to the chassis in a certain way.
Not suggesting that the solutions aren't safe, just that they don't meet the letter of the rules.
They used to do bolt-in aluminum cages for steel chassis cars, too.
Actually the bolt-in method is legal to the letter of most sanctioning bodies' rules. In fact, as far as I've seen so far only the JAF rulebook requires that you use epoxy in addition to bolting when attaching a steel roll cage to an aluminum chassis, and even that's only for certain classes. In all of the other common classes in the US (FIA, SCCA, NASA, NHRA) you only need a bolt in cage for a car with a factory aluminum monocoque.
Lemons and Luckydog say must be welded, that is 66% of my universe..champ says bolt-in ok.
The OP asked why-not, that is what I came up with. Nobody has done an Insight for lemons.
nimblemotorsports said:Lemons and Luckydog say must be welded, that is 66% of my universe..champ says bolt-in ok.
Yet LeMons will attempt to destroy your car if you over build it. [Insert eyes rolling]
No rulebook is perfect. At some level a cage starts to not need the rest of the car anyway. Semantics are blah, but living is good. If you want to run one, maybe point out the flaws.
