amg_rx7
amg_rx7 Dork
2/26/14 3:10 p.m.
Engine is apart. Now's the time to install an oil temp sensor (or is it sender?) into the Miata's aluminum oil pan.
Should I just drill and tap the pan for the 1/8" NPT sensor or drill and weld a bung into the side of the pan?
Which approach is better and why? Is one approach more prone to leaking?
Thanks.
Kenny_McCormic
Kenny_McCormic UberDork
2/26/14 3:34 p.m.
Unless its 1/4"+ thick where you want it, I'd bung it, especially if you already have the pan off.
ncjay
ncjay HalfDork
2/26/14 3:39 p.m.
Agreed. Most oil pans are too thin. If you can't find a spot thick enough to drill and tap, it needs a bung. Properly done, it won't leak.
amg_rx7
amg_rx7 Dork
2/26/14 4:02 p.m.
Thanks. Ordered the bung from good ole' Pegasus.
2/26/14 4:09 p.m.
Opposing view: drilling and tapping will work. It only has to be strong enough to support the sensor. We've been drilling and tapping the pans for years for turbo oil returns and I don't think I've ever heard of one failing. That cast aluminum is relatively thick.
Alternately, you could drill and tap the drain plug. Makes for a super-easy install but if you bottom out the pan you'll remove the wiring. Of course, you shouldn't be using your oil pan for a skid plate...
GiF3gZcSRorgkV92PW2sTva5Gz0ZbER7tY5N8rpSAOmlN2O1BSKNzrDx8pA9WxAr
