As anyone on here done a V8 swap into an older Jaguar (I was thinking Jaguar XJ6 or XJS). How hard a swap is it? How do they drive? And can you fit A/C to one?
Ok any ideas on how hard it would be to run a manual transmission in one? Also how much does an LT1 engine cost?
If you're having to buy the engine and not something you have sitting around, skip the LT1; they're not bad but the LS type motors are definitely improved. And if you shop you can pick one up with under 100k miles in an aluminum block variant for $700 or less.
A guy in our English car club has one (SBC) in a XJS. The AC works, it drives fine, and if I recall, he said it has more umph that the V12 that was in it. As in "I can start that hill at 40 and be doing 70 at the top." (It's a big hill.) To which I replied "I can start that hill at 0 and be doing 100 at the top." (theoretically....)
NOHOME wrote: L33. Cheap, truck sourced goodness.
Will any transmission that goes behind a LS series work with an L33?
96DXCivic wrote: Will any transmission that goes behind a LS series work with an L33?
Yes. And apparently with the $60 flywheel from an '07 and newer 4.8L you can also put any manual from any old SBC behind it as well.
I've seen arguments about these swaps that go along the lines of "You've swapped in a LS engine,good transmission etc. That's still not gonna keep the window from falling out during a rainstorm when you're 200 miles from home."
oldopelguy wrote:96DXCivic wrote: Will any transmission that goes behind a LS series work with an L33?Yes. And apparently with the $60 flywheel from an '07 and newer 4.8L you can also put any manual from any old SBC behind it as well.
Except the Corvette ZF6: bellhousing is too small. There may be others.
This is at a dealer near me, and the pictures represent the car well. If I had more time, I'd snatch this one, re-wire it and drop something more interesting in it.
Well good then. You don't have a problem! I'm kind of in the same situation, but I keep seeing that car sitting there. It's been on the lot since last winter. I bet I could pick it up really cheap.
So if I was going to do a Jaguar with a V8 swap and a manual transmission, how would I do the pedals? This guy uses Jaguar pedals sourced from the UK but that seems $$$$$. Any other ideas.
http://jaguarspecialties.com/project1.asp
If you have the fab skills to do a major engine swap, it shouldn't be too hard to adapt a three pedal setup from a junkyard car. I'd just go find one that looks like it would work and make it work. Shift kits help shifting, but unless you convert to a manual valvebody, you still have no control over the shifts.
96DXCivic wrote: So if I was going to do a Jaguar with a V8 swap and a manual transmission, how would I do the pedals?
Wilwood is an excellent product, great quality, lasts forever, tons of choices. You didn't hear cheap in there did you?
J.C. Whitney has some also, cheaper. The one below is ~$140. I have a Wilwood master cylinder with three types of fluid reservoirs, IIRC it was half the cost. Poke around JCW.com and the get up under the dash to see what you have. A hot-rod with an automatic, sacrelidge.
I was thinking about those aftermarket pedals (Wilwood or Tilton). That may end up being the route I go.
