I don't know what's going on with the forum but I made a post and got an error message. I refresh the page and it showed a post by me but nothing in it. So I don't know what's going on but, my issue is I'm having a hard time jacking up my e91. Stock suspension and every time I put it on this bracket by the arm it slips off the bracket and the car lands on the arm on the jack stand. I don't see any where to put the jack stands on the side frame. So I don't know where to put my jack stands. And also the form is not letting me upload a picture.
Dont use that!! Best case you bend the suspension arms, worst case you get flattened by the car. Use the jackpoints on the side and lift it from the differential and front jack point. I will try to get picks in a second
I like that but how do you get the jack stands under the front jack points when I need those to jack up the car?
I looked a little higher and went with the frame bolts...
Use the jack pockets under the doors. Turn the jack stand perpendicular to the pocket. You don't need to use the adaptors BMW wants, but without them you will tear up the plastic a bit.
there is a central front jack point a bit in front of the oil pan. Rear, use the differential.
If you have trouble getting your jack under the front or back of the car to hit the points Dneikirk and Slippery mentioned drive the car up onto some wood boards to gain clearance first.
Small block of pine 2x4, it'll sink into the jack pad "prongs", and place it under the flat subframe.
