1 2 3 4 5 6 ... 11
fidelity101
fidelity101 Reader
10/15/12 10:54 a.m.
86 rx7, 200,000K miles + bought it almost 8 years ago at 145k miles, daily drove it for about 3.5 years. 5th motor (since 86)
not sure on true mileage anymore since there is no odo/spedo
We just sold my dad's 98 prelude si. he was getting it service for an oil leak (bad cam seal) it went 197k miles on the stock timing belt, it wasnt even damaged! but since it was literally twice the mileage due for one he had it done. Sold the car shortly after though because everything else on the car was starting to fall apart. Original owner
dinger
dinger Reader
10/15/12 11:03 a.m.
2000 Ford Excursion with a 7.3 Powerstroke Diesel, 239,000 and counting. PO put a new longblock in it 50,000 ago when it dropped a valve. Pretty sure the transmission has been rebuilt, front end parts have been replaced. Bought it cheap and it makes a hell of a car puller.
old_
old_ New Reader
10/15/12 12:04 p.m.
89 crx dx, 385k (yes 385k), original engine, original transmission
replaced: brake booster, brake master cylinder, radiator, clutch (once), and normal maintenance stuff like pads, tires, fluids, filters, etc.
that's it
Knurled
Knurled GRM+ Memberand SuperDork
10/15/12 6:00 p.m.
midniteson wrote: Got a car with high mileage? Year, make, model? If known Whats been replaced? History?
'86 Quantum Syncro, odometer just rolled over 350k. I know for a fact that the odo was inop when I bought the car (it read 268k) and after I fixed the odometer (set it to 298k), there was an additional 7500 mile period where the speedo cable was broke. Basically, 350k is as good a guess as any.
I replaced the rearend about 50k (actual) ago because I thought it was noisy. It wasn't. Engine, trans, and clutch are original. Engine has the compression of a Briggs & Stratton with the E-Z-Start mechanism stuck on - coast for miles in gear with the engine off.
This:
just rolled over 206k. Bought this one at 147k indicated. It similarly went about 10-15k with an inop speedo after transmission debris took out the speedo drive and driven gears. It's had... many engines, transmissions, and rearends. It came with a severely worn out 12A, blown struts, body damage, and a bent rearend. Much work has been done.
noddaz
noddaz GRM+ Memberand Reader
10/15/12 7:29 p.m.
In reply to midniteson: 1992 Maxima 249000 and rusting out, time to replace her... 1997 Jetta 250000 and time for an oil change 1986 GTi something like 220000
Feedyurhed
Feedyurhed Dork
10/15/12 8:11 p.m.
Feedyurhed wrote: I have a friend who uses a 70s Chevy cube van with a stock 350 SB as his work truck. He claims he's near 1 million miles on the basic motor, frame and body work. Of course he's replaced maintenance items many times. My mailman has a 1976 Chevy Caprice also with a 350 that has 750K on it, or so he claims. I have an XJ with 160K. Just a baby.
Checked with my friend with the cube van (1979) today, he's at 1,015,000 miles. 2nd motor, original aluminum body work. Still has the original wiper motor, switch and gear. The only parts that have never been replaced, worked or needed servicing in any way, as far as he can recall.
He also has a 1951 Chevrolet coupe with only 46,000 original miles.
Powar
Powar Dork
10/16/12 3:01 p.m.
Our '94 Protegé DX is at 212k miles or so now. It has become my girlfriend's daily driver when we don't commute together in the Fiat. As far as I know, it is on its original engine and transmission. The clutch has been replaced at least once. It burns a bit of oil on startup, but doesn't leak anything (onto the ground, at least). Since I bought it, I've replaced the front lower control arms, steering rack, ball joints, swaybar endlinks, exhaust, headliner, front and rear seats, springs (with Ground Controls), wheels, tires, radiator, etc etc etc.
The car should have gone to the junkyard, honestly. It led a hard life. I can't complain too much, though. It has been a low-buck project and we now have a decent-looking fun and efficient car for her to beat around in.
Bobzilla
Bobzilla UltraDork
10/16/12 3:38 p.m.
the only high-miler I have right now is:
2000 Accent GL sedan. 1.5L/5-spd. Cold as ice AC, slow as balls, 206k on the odo. Odo was stuck at 188 for at LEAST 3k miles so it 's pushing 210k miles on it and runs super strong for 90hp. replaced the trans (diff popped after the wife popped a 10" curb with a 13" wheel and trashed the bearing too) at 116k. Replacement critter had 62k miles on it.
noddaz
10/16/12 4:12 p.m.
Funny thing. In this place it might actually be a shorter list of who doesn't have a +200k mile driver...
Kenny_McCormic
Kenny_McCormic Reader
10/16/12 4:31 p.m.
Rust usually kills them before that point.
I had a 98 Mitsubishi Mirage(aka "The Rage") that lived a hard 220k for a summer where I added 5k to the odometer, the lifters made a lot of noise and the clutch was on its last legs, shocks were pretty much dead, exhaust was nonexistent, but it ran ok. I sold it for what I paid for it when I noticed the rust around the rear upper control arm mounting points, one more winter and there likely would have been control arms in the trunk, drivers floor was going too. The rockers were solid oddly enough.
The current DD Sunfire the replaced the Rage (aka E36 M3fire) will also be condemned to somebodies $800 first car after another winter due to rust, it just rolled 188k. I have under $1k in it including a crash that required half the front suspension to be replaced. Bought for $400 with 162k on the clock with a noisy timing chain and very loose front end. I think I've gotten my monies worth.
McTinkerson
McTinkerson New Reader
10/16/12 4:49 p.m.
I had a 2002 Subaru Forester with 350k km on it when I sold it. Had a new clutch when I bought it, replaced the rest of the hydraulic system components (bad master). Needed new consumables (plugs, etc.). Replaced the seriously worn suspension with factory 2005 FXT pieces. Engine was starting to burn a little oil towards the end and the fuel filler was throwing a CEL. Only rust was on the rear tailgate under the window and along the rear fenders due to the stupid factory plastic lip guards. Bought for $3.8k, tossed in $1k worth of parts, drove it for 70k km+ and sold it for $5k. I would buy another in a heart beat once I had an actual garage to work on it.
WilberM3
WilberM3 Dork
10/16/12 9:29 p.m.
both of our challenge cars have quite a bit, the jeep XJ-R is at 243k and the e30 has 252k
Moving_Target
Moving_Target New Reader
10/16/12 9:36 p.m.
'90 Ranger - 455,000km (heh, my sister did lots 'n lots of highway driving before I got it)
'94 Crown Vic - 300,000km (bought from a little old lady w/170,000km)
'86 Mustang LX Notchback - odometer broke and I've swapped clusters so no frigging clue (bought with ~180,000km if memory serves)
'93 Mustang LX Hatchback - something over 200,000km
I squeeze my vehicles.
Shaun
Shaun HalfDork
10/16/12 11:06 p.m.
Very impressive numbers being posted here. I'll add:
1995 volvo 850 t5r wagon bought at 95k now at 195K miles.
brakes, tires, intercooler circuit rubber, hoses, filters, oil & blah blah (eats tires for sure)
17 psi ECU, front suspension everything, and cat back at 95k rear mail seal at 100k (ouch) radiator, water pump, serpentine and timing belt at 130k drivers seat motor cable at 160 k or so rear suspension bushing at 170kish used 2002 16t turbo with big angle flange and 3" downpipe at 180k
water pump (oem this time), timing belt, tensioner, idlers, serpentine belt, cam seals, alternator, condenser, evaporator, compressor, power steering pump, fuel injector service, pvc system, rebuilt axles, and right front control arm at 190k. Most of this was done "while I was in there".
engine and transmission seem to be going great, uses a quart of oil every 5k or so. hauls ass- black leather interior holding up really really well.
needs sunroof rebuild, seals at the axles, and a motor mount or two.
ronholm
ronholm Reader
10/16/12 11:13 p.m.
This one has just a few thousand short of 300K...
http://grassrootsmotorsports.com/forum/build-projects-and-project-cars/turbo-5spd-1990-dodge-caribou/55856/page1/
Caleb
Caleb Reader
10/17/12 10:10 a.m.
1994 infiniti g20-t :Bought with 160k with a bad clutch for 300$ it now has 227k and is my DD replaced the clutch,radiator,power steering pump,AC compressor, belts,knock sensor, 2 sets of injectors,MAF ,temp gauge sender unit and plugs and wires and the SR20DE is still going strong
On the body 2 wheel bearings, both back calibers and swaybar links and front ball joints
former520
former520 Reader
10/17/12 10:14 a.m.
90 LS400, 242,000, bought at 187,000 with full dealer paperwork of repairs. Still going strong.
midniteson
midniteson New Reader
10/17/12 12:38 p.m.
noddaz wrote: Funny thing. In this place it might actually be a shorter list of who doesn't have a +200k mile driver...
Ha very true!, its awesome to see all the different types of vehicles on here that have covered so many miles!.
Wayslow
Wayslow Reader
10/17/12 1:50 p.m.
376k on a 2004 Chevy Cavalier. Picked it up as an ex daily rental with 30k. Drove it until a couple of weeks ago when a guy ran a stop sign and wrote it off. Boring to drive but it did the job for 7 1/2 years so no complaints.
Replaced the cv joints once along with the front wheel bearings. Replaced the alternator about two months ago. Other than that just brakes, tires and oil changes. It still had the original transmission fluid in it.
Moving_Target
10/17/12 2:58 p.m.
Heh, the bane of the auto manufacturers.
Curmudgeon
Curmudgeon MegaDork
10/17/12 3:23 p.m.
Not mine: there's a guy on the Jensen Healey board who bought his J-H new in Cali, it is his daily driver and has over 400k on it. Routine maintenance, a couple of clutches, alternators, starters etc, the head came off for a valve job at ~375k.
93EXCivic
93EXCivic MegaDork
10/17/12 3:24 p.m.
In reply to Curmudgeon:
I didn't think Jensen Healeys could make it to 40k miles....
fatbusdriver0984
fatbusdriver0984
4/28/15 10:32 a.m.
I have a 2002 Dodge Caravan with 310,000 miles. She was a former school vehicle. Needs a few minor repairs and some PM that she didn't get as a fleet vehicle. Great running condition, though. I've had other high mileage cars in the past I had a 1987 Mercury Grand Marquis wagon with 280,000 miles on it, a 1994 Oldsmobile Bravada with 240,000, and a 2000 Geo Prism also with 240,000
gearheadE30
gearheadE30 Reader
4/28/15 10:59 a.m.
1991 BMW 318is, bought at 198000 miles and now has about 268000 miles. Turbocharged around 250000 miles on an untouched bottom end, but the head was refreshed. Stock except for ARP studs. Runs great, no leaks, barely any rust, and takes 8 psi all day.
4/28/15 11:00 a.m.
I'm such a rookie: 215,000 or so on the 240SX.
1 2 3 4 5 6 ... 11
DUn49fkiMfY4Ul8d7BpJjYMcBz5eC3vfDFlHJMhKrta3sB0bLJ8JO8JINmpHWI30
