1 ... 11 12 13 14
Professor_Brap (Forum Supporter) UberDork
10/14/24 12:37 p.m.
10/15/24 5:42 p.m.
Some previous previous owner notes.
secretariata (Forum Supporter)
secretariata (Forum Supporter) GRM+ Memberand UltraDork
10/15/24 6:24 p.m.
Is that in yen?
10/16/24 11:53 a.m.
In reply to secretariata (Forum Supporter) :
 Kinda having a hard time following their math.
Unsure if it's miles or dollars.
10/16/24 12:03 p.m.
Got bored and pulled the clutch master cylinder apart and I was not disappointed.
The bore is super gritty.
the plunger has damage and one seal has a slight tear.
10/18/24 9:22 a.m.
Fresh grips on, I had hand guard off anyways and I can't stand spinning and sticky grips.
10/19/24 9:33 p.m.
New goodies.
Reverse bleed, and test ride incoming.
10/24/24 10:04 a.m.
First couple rides went well, had a misfire under any kind of load, checked plugs (super nasty) and changed the small inline fuel filter.
Cleaned the plugs, ordered some new ones and let's try again.
Runs beautifully now, clutch works great. Zero complaints on how it runs.
One major issue I have found is the front rotor is warped/bent. Abs on or off it has a weird grab or pulse when you grab it. Checking that out soon.
11/1/24 8:29 p.m.
Front rotor is definitely bent, rear brakes are pretty smoked so I ordered front rotor, and front and rear pads. Also researching false neutral eliminator kits.
Absolutely love the bike, got some small fixing to do, but will get it how I want it in no time.
11/8/24 12:30 p.m.
Bounce back for great gravel roads in southern Ohio on the Drz.
11/20/24 9:03 p.m.
Got some goodies for the 701
After some pulling it apart, rotor is a 300mm rotor for a Enduro.
Bunch of cleaning, some new parts and now the brakes feel so amazing now.
So what I found was the top of the rotor was hitting the pads and giving my wild feelings.
GCrites
GCrites Dork
11/20/24 10:46 p.m.
Oh gosh, I've never seen that before! I can see how it could happen though.
11/22/24 11:28 a.m.
Same, but was glad it was something not to major.
11/25/24 6:46 p.m.
The shockingly clean air filter and filter sock. All clean and oiled now and with a fresh pc racing sock.
12/3/24 12:44 p.m.
Installed a factory pro shift fix kit! Way to cold to go ride, but I am excited to ride and see if it helps with false neutrals.
12/10/24 6:57 p.m.
Looking good!
New to me supermofools headlight and a acerbis skid plate.
12/13/24 7:28 p.m.
Bike has a power commander now, map switch (dual tune), launch control set-up, and under seat bag on.
12/14/24 9:01 a.m.
Little video clip of it.
12/16/24 12:26 p.m.
Did a rear pad spring (didn't get a picture)
Safety wire setup for oil cap
Rottweiler rear master cylinder skid plate
12/20/24 9:43 p.m.
New vanasche gas cap, wanted this since I got it day one.
Sae charger cable, and small voltage gauge and USB adapter to put in under seat bag.
ae86andkp61 (Forum Supporter)
ae86andkp61 (Forum Supporter) GRM+ Memberand SuperDork
12/20/24 10:03 p.m.
Nice work; looks like you're making it your own with some useful mods!
I recently received a package with some 701 goodies in the mail; thanks a bunch! 😁
12/21/24 9:07 a.m.
In reply to ae86andkp61 (Forum Supporter) :
Thank you! It am trying to make it work better for what I like to do, and have it all ready for spring.
Glad you got your box of goodies!
12/22/24 11:26 p.m.
This bike has been super loud since day one, so pulled the pipe to see if there was any packing left.
there was none left.
This is all that was in there.
Put some heat tape on the gas tank since everything was apart to try to keep some heat out of the tank.
Repacked the muffler, put in a DB killer and it's not bad at all now. Might pull DB killer tomorrow and bring it with me and ride around some and decide what way I like it.
12/30/24 6:41 p.m.
Crash protection day!
Bar end sliders, axle sliders, foot peg sliders, exhaust slider and frame sliders (came back off). Also some titanium rotor bolts and rear abs sensor cable protector.
1/12/25 5:09 p.m.
Warp9 21/18 setup for the 701 so I can do some ice racing this winter.
Side note: everyone says you can't do this. Rear bolted right up, front just took SM spacers, sm rotor spacer and rotor and the smallest amount of grinding on the caliper to not hit spokes. Yes I know geometry is not ideal, but for ripping around on the ice it will be ok.
1 ... 11 12 13 14
j8qoXkaoafyOMcXrxxOfIYHiy3oXlHfxT3c97kJaVfJ6qBhkAb64yzvWbPuF31rJ
