Can I cut 4 equal sized pieces of 4x4 and use them instead of the rubber blocks to raise my corvette? The corvette has jacking pucks that sit proud of the body by ~1/2" and while I can slide the quickjack under the jacking pucks when adding the extra height of even the small rubber blocks it just BARELY doesn't fit. I have done the drive onto a 1x12 to give me the extra 3/4" that is needed but i'm wondering if I cant just cut 4 pieces of equal sized 4x4 and use them in place of the rubber. I would measure and cut them to be the same size as the recess between where you place the pads and the frame.
Thoughts?
Quickjack actually makes a lower profile block: https://www.quickjack.com/1-5-low-profile-blocks/
I went out and measured the existing blocks and they measure 2 5/16" so at 1.5" these will be roughly 5/8" of an inch shorter and should be perfect.
Since I don't have a 2x4 piece of hardwood laying around i think i'll go with these.
I have used chunks of 2x4 on a quickjack in the past. It worked OK, but yes, they will have a limited life and you'll need to make new ones eventually.
In reply to JFW75 :
So do Dicks and Play It Again Sports and Canadian hardware stores - if you don't want to support Amazon :) Heck, stop by your local rink and ask if they have any that are too chewed up for play.
In reply to Keith Tanner :
I guess you can take the Canadian out of Canada, but you can't take the Canadian out of the Canadian? ;-)
brandonsmash said:If you have the ability to cut a 4x4 would you not also have the ability to cut down the QJ pucks?
no... i would use a sliding mitre saw with a block to create a consistent size, thats easy and safe because the source material will give me a place to hold the material well away from the saw blade but the quickjack blocks being a max of 3" and needing to cut them down to ~1.5" would make it too small to clamp down the working tool and dangerous to hold with my hand. Additionally the saw blades I have for my sliding saw probably would heat/melt the rubber as they were cutting it.
however that lead me to discover that quickjack makes a 1.5" tall block and that would be the right height out of the box.
procainestart said:In reply to Keith Tanner :
Too true, eh?
The rubber blocks on my old Bendpak scissor jack failed last weekend, so I made these up out of an oak stair tread which is 1" thick, I dado'ed out the slot. I haven't had time to test them yet, so it may turn out to be a complete failure 🤷♂️
I have been using 2x4s and 4x4s for 35 years now on my old single post lift and current 2 post, mostly to protect the rubber pads.
In reply to Apexcarver :
Nothing, it's on top of a rubber pad that is probably 5 x 5", they do occasionally get stuck to a screw or sharp pinch seam.
