In the October Issue | Joint Venture: Quick Tips for Joining Aluminum
J.G.
By J.G. Pasterjak
Jul 21, 2020 | aluminum, Welding, Shop Work
Photography Credit: weldscientist
Anyone who’s ever had a track car has probably done some aluminum fabrication.
Whether that was a simple hand-formed bracket, or a more complex structure, aluminum’s low cost, ease of availability in big-box stores, high strength-to-weight ratio and mostly benign nature make it the perfect material for even the novice fabricator.
But when it comes to joining two pieces of aluminum, what’s the best method? The answer is that there’s probably isn’t a single answer, but a range of options that vary based on the material, available time and skill of the fabricator.
Subscribe now to get our October issue, where we’ll run through some of the more common options you’ll likely have access to in your home shop, and the pros and cons of each.
Join Free Join our community to easily find more aluminum, Welding and Shop Work news.
Comments
Really looking forward to this one. Every time I get into brazing/soldering/welding different types of aluminum my head begins to spin a bit and I just push the project to the side.
FOkim9bfQGY6iso8D2kv9WwDZPdqvBMxUAoMb41TjgfpbxdnY7phz6PCW6zsskpX
