122-Sweet
Per
Update by Per Schroeder to the Volvo 122s project car
Oct 15, 2001
Sponsored by
The stock fuel pump was removed, and a blocking plate was used for the subsequent hole in the engine block. An electric fuel pump now resides back near the tank.
The KG Trimning header is a 4-2-1 design
Handling wise, you can see that the 122 is *reasonably* flat on a skid-pad, however, there is some evidence that it needs a stiffer front anti-rollbar.
0-60 run
The Volvo continues to be a great source of entertainment, both in the garage and on the road. We recently drove down to Naples, FL to visit with some relatives. The non-overdrive 4-speed transmission meant that the engine was spinning at nearly 5,000 RPM for any sort of highway speeds. This caused some oil leaks that quickly went away after some around-town driving. Earplugs were bought for this trip.
The KG Trimning header was sent to Jet Hot and coated with their ceramic material. This combination of Tri-Y design and high quality coating have improved performance. How much performance gain was made will be determined on the dyno soon.
The KG Trimning header is a 4-2-1 design. Dyno testing will be done 10/25/01 to see how it compares to the IPD unit.
We’ve scheduled an appointment with BSI Racing for a tig-welded rollbar for the Volvo. This will allow us to compete in some track events in the future.
And we got a chance to do some testing of the 122s and were very pleased with the results. On our .6 mile test track, the old girl came across the line with a low 46 second run. The Lexus IS300 5-speed we tested the same day was only half a tick faster.
This time around, the 122s got a 8.5 second 0-60 mph time. This was only a slight improvement over its 8.6 of a few months ago. Reason? The shorter tires and new rear axle ratio mean that 60 MPH requires a second-third gear shift.
Comments
Sponsored by
GRM Ad Dept
xy32b9cLiMmC86wYAeV0Pk9fG9T7cyWk7uV3EychCjyZUMxs2m48knpbqDKsVfjJ
