Dixie D’oh!, Part Deux
Per
Update by Per Schroeder to the LeGrand Mk 18 project car
Jun 4, 2010
Sponsored by
Please insert new engine.
We'll be building a new engine using the pieces of four other engines. Fun stuff.
The Moroso accumulator should save our next engine from a similar fate.
We attended the Southeast Divisonal Championship event hosted by the Dixie Region in Moultrie, Georgia, a few weeks ago. We were in the middle of our second runs on Saturday when we noticed some clicking from the engine. The noise got worse, and we trailered the car after our third runs.
A post-race postmortem indicated that we had spun the No. 4 connecting rod bearing. We had a similar problem with our first ZX10R engine—although in that case, we spun No. 3 and No. 4 due to oil starvation. We’ve come to the painful conclusion that our oil pan is simply not up to the task of keeping oil near the pickup for the oil pump. We’ll have to come up with an alternate solution.
Part of that solution will be the installation of a Moroso (http://www.moroso.com) accumulator. This 1.5-quart accumulator will feed oil to the engine in the event of a loss or decrease in system pressure. At less than $200, this 8-pound device should help our engines stay together in the future.
We will be rebuilding this ZX10R engine. So far we’ve sourced a good used crankshaft ($230) as well as pistons with connecting rods ($65). We’ll be ordering connecting rod bolts, gaskets and a head gasket shortly. The only big-ticket item will be a new oil pan with an alternative oil pickup. We’re still researching that decision now.
Comments
minimac
minimac SuperDork
6/8/10 2:20 p.m.
Not trying to be a wise arse, but is anyone else running a similar engine? Look and see what others are running before finding out the hard (and expensive)way what works and doesn't.The accumulator might save an engine, but could hide the problem.
Per Schroeder
Per Schroeder PowerDork
6/8/10 3:57 p.m.
Actually, some people are running ZX10s----plenty for dwarf cars, but very few for DSR/BMods. The problem is the pan--and we're working to fix that correctly. The accumulator is just added insurance above and beyond that.
iceracer
iceracer PowerDork
6/8/10 6:14 p.m.
On air cooled VW's their used to be a small sump with an extended pickup. Bolted on in place of the screen plate.
Jerry From LA
Jerry From LA Dork
6/13/10 12:36 a.m.
Look at the bright side. You're getting really good at pulling the motor really fast. :)
Two questions: 1. Since you're mixing and matching parts, will you be balancing everything? 2. I understand, the original motor is different but is there anything relatable design-wise to the newer powerplant(s) regarding oiling? After all, the original engine stayed together so what is /was different about it?
alfadriver
alfadriver UltimaDork
6/15/10 9:50 a.m.
Since a lot of FSAE cars use bike engines, and should get this kind of oiling issues, what are they doing?
Could always dry sump it... :o
Sponsored by
GRM Ad Dept
DgXwBgIzFdiupXnAfJq549AREqonlmT6fH03SdkridcsEyqj5YWBXEdwPZAot751
