First Try at Carbon Fiber
Per
Update by Per Schroeder to the LeGrand Mk 18 project car
Mar 29, 2011
Sponsored by
We felt that that our front splitter was underutilized.
We cut out two 11x14-inch sections of the splitter.
We cut and glued together three pieces of blue insulation foam to create a male "buck," which was then sanded into the correct shape.
We then cut out a piece of carbon and laid it over the foam.
Slow-curing epoxy was then brushed onto this first layer.
The entire splitter was then coated with a layer of epoxy and laid over the two diffuser sections.
A second layer of carbon fiber material was then laid down and epoxied into place.
Once the element had cured, we trimmed the excess and mounted it back on the car.
Instructions are helpful when you’re learning a new skill, but often it’s better to just get your hands dirty. We’d watched people lay up carbon fiber, but we’d never done it ourselves. We picked a small project to get our feet—and fingers—wet.
We’re unsure how effective a front wing is on the LeGrand, but it’s pretty obvious that underbody aero is an area where we can improve our car’s downforce with minimal penalties in drag. We started with a pair of diffusers (sections of the underbody that expand to create low-pressure spots) mounted ahead of the front wheel. Theoretically, they should help our front grip at speed.
Comments
Sponsored by
GRM Ad Dept
IWfLirIAw6fddiUeYJHWdNG5UsszSz6j7KcCVXYNZWb98CPUOyQC9vqzsTlfyCJe
