Full-Frontal Aero
Per
Update by Per Schroeder to the LeGrand Mk 18 project car
Aug 19, 2010
Sponsored by
We mounted the 5.5-inch element to pieces of scrap .090-inch aluminum that we fastened to the splitter.
The new front splitter that is about 1.5-inches farther forward than the old version.
At our last two events, we felt some understeer and possible lift at the nose of our LeGrand. This led us to believe that the rear wing is certainly working to keep the rear wheels planted at speed and that a front wing was in our future.
We don’t have the budget for custom elements that cost $1000 a piece, so we came up with a game plan that used an off-the-shelf carbon fiber element from a “universal wing,” some scrap aluminum, and a sheet of half-inch hardwood plywood.
The APR wing element we purchased from Ciro Design was formed in a silver carbon weave. That clashed with the rest of the car, so we gave it a quick spray of black paint. The element itself is quite nice; it weighs about 2 pounds and appears to be strong enough to take the hit of a pylon. The kicker is that it was $100 shipped to our door.
We made a new splitter out of the plywood, extending it about 1.5-inches. This gave us enough space to mount some brackets that we fashioned out of .090-inch 6061 T-6 aluminum. The whole assembly weighs under 8 pounds.
Comments
CamaroKeith
CamaroKeith Reader
8/16/10 5:23 p.m.
This is really making me want to buy one of these...
Fireba11s
Fireba11s None
8/16/10 9:47 p.m.
Great start, but it will produce a lot more downforce if you drill another set of holes in the end plates and move the wing up to the top of the end plates. The wing produces low pressure on its lower surface, but it also produces low pressure on the upper surfaces of the splitter and nose because they are so close together. The flow through that slot is a lot like the flow through a carburetor venturi: no net force in any direction. More separation will reduce that destructive interference.
While you are at it, you may as well slot the aft bolt hole on each side for some adjustability.
There is some simple and effective guidance about using Gurney flaps for low speed racing in the aerodynamics chapter of my new book, Think Fast:
http://thinkfastbook.com
If GRM is up for it, I would be glad to write a race engineering Q&A column.
Neil
Per Schroeder
Per Schroeder PowerDork
8/19/10 9:38 a.m.
We don't have the budget for custom elements that cost $1000 a piece, so we came up with a game plan that used an off-the-shelf carbon fiber element from a "universal wing," some scrap aluminum, and a sheet of half-inch hardwood plywood.
Sponsored by
GRM Ad Dept
fVT44vjCDHnscjdtQfrz1ePEBd2LXMg7EER39M5bdwPFEwyOW1aTFZ7LYSiYER4A
