Reanimating Our Monster
Per
Update by Per Schroeder to the LeGrand Mk 18 project car
Jul 16, 2010
Sponsored by
We built the engine in our garage. Despite its strong performance, the engine is actually quite simple.
One of the cylinder heads that we had on hand sported broken intake valve retainers. We wound up not using it for this reason and went with our other head.
Here's our Schnitz Racing oil pan with the swinging pickup. We also installed a baffle plate to keep oil from sloshing upward.
And the engine goes back in. The complete engine and transmission only weigh 130 pounds, so this hoist is a bit of overkill.
We spent the weekend putting our LeGrand’s Kawasaki ZX10R engine back together after its oil starvation issue. We sourced a good used crank and a set of used rods along with new gaskets from Cometic. The oil pan was replaced with a billet piece from Schnitz Racing—it’s got a pickup that swings around so that it will stay where our oil is. We supplemented it with a baffle between the block and the pan. These changes, along with our new Moroso oil accumulator, should keep the motor happy.
Comments
Jerry From LA
Jerry From LA Dork
7/17/10 11:12 a.m.
The hoist ain't overkill. The tub is wide so the liftover would be very awkward. Exactly the type of lifting my back shows little tolerance for. Reaching away from your body with a load is not good. Besides, every time you uses your hoist justifies the money you spent on it.
Per Schroeder
Per Schroeder PowerDork
7/18/10 7:58 p.m.
Oh yea, it's been used on the Saab a few times and has now put the LeGrand engine(s) in 5 times. My insurance copayments for another single MRI would take care of the hoist cost......I'm about a year post ruptured disc, so I'm very aware of the issues :-)
Sponsored by
GRM Ad Dept
T6MdnT874gL4JR1fVApAXoFS7qiG7rkshMpHUL86fyEbD9Xf9oNAHdu2pneNdBne
