Seat, Stickies and Storage
Per
Update by Per Schroeder to the LeGrand Mk 18 project car
Feb 16, 2009
Sponsored by
The kart seat had leg supports that we didn't need.
We cut down the seat and riveted it into the car. We'll be supporting its sides with foam.
The new Keizer wheels look great, and we saved about 5 pounds per corner.
The rear wheels are taller to help our gearing.
The tire rack is sturdy and holds our spare wheels easily.
This weekend, we had the chance to get a few small tasks done on the LeGrand.
First, we took a fiberglass seat for a sprint shifter kart and cut it down to fit inside the LeGrand’s tub. We’re just using the back section of the seat; we’ll be using a two-part foam to give the sides more support.
The tires we were using were well past their prime, so we took the opportunity to mount up the fresher R25B tires and Keizer wheels.
The tires are a bit narrow at 7 and 9 inches wide. However, the rears are a little taller at 22 inches, which will better suit our gearing.
Meanwhile, we mounted up a lightweight aluminum tire rack in the enclosed trailer. The rack bolts through two of the steel girders that give the walls of the trailer some stiffness. We now have a place for four of our spare wheels and tires.
Comments
Sponsored by
GRM Ad Dept
bBMBcrSGDlhOZSfwm1Br5ca5DbB96gfrOZrYiEvcly6PQIxQQWVFXwHdS9BDMkTz
