Primed and ready to go…sort of.
Per
Update by Per Schroeder to the Subaru Impeza project car
Aug 5, 2005
Sponsored by
We primed the nose of the Impreza last night, taking our car from multi-colored to simply bi-colored. With primer on, you can see some of the fitting issues we’ve had, since the nose of the car was pretty tweaked. The end result will look ok at speed and will be well-covered with vinyl, so we’re not overly worried about the gaps.
We’ve also sourced a set of used 2003 WRX springs for our Impreza. We’ll be using at least the fronts to get a little more rate and ride height in to our Impreza. The set was $40 from a local autocrosser.
Comments
Sponsored by
GRM Ad Dept
m7YqeHFYz020h2wygYggHWDTGe9smzxgtfsOCYeV1E5fQGEjItVOemE9LCecywnh
