Bomb-proof hubs for our endurance race Miata? Yes, please.
Tom
Update by Tom Suddard to the Mazda Miata project car
Dec 14, 2024 | Mazda, Miata, Mazda Miata, MiataHubs.com, Wheel Hub
Sponsored by
Photography by Tom Suddard
Nobody likes it when the wheels fall off their race car. And sadly, the wheels on our V6-powered Miata wanted to come loose.
We had already taken a step to fix this, as we had ditched our Miata’s stock fragile front hubs for a redesigned aftermarket setup featuring user-serviceable tapered roller bearings.
In theory, it was the perfect solution: The new hubs would be durable, adjustable and use less expensive consumables. We’d no longer burn through the stock replacement bearings.
But in practice, it just didn’t quite work: Once on track, we found ourselves needing to tighten the hubs every few hours as they kept slowly loosening up. This bearing play also caused annoying pad knock back.
Leave the problem unaddressed long enough, and you could end up right back in “my wheel fell off” territory.
Clearly we needed a better solution, so we went with the gold standard in Miata hub upgrades: MiataHubs.com V2.0 Billet Enduro hubs.
They’re pitched as “a consequence of over 5+ years of development and testing.”
They feature a cartridge-style, two-row tapered roller bearing as well as seriously beefy construction.
Other teams in the paddock already told us what to expect: Bolt them on and then completely forget about the front hubs forever.
These hubs even come with extended lug studs pre-installed. And yes, we know, we know: It’s still a good idea to inspect your hubs–and everything else on the car–after each track event.
But the anecdotes we heard were that MiataHubs.com parts didn’t just last multiple races, they lasted multiple years without showing any signs of wear.
So what’s the catch? They cost $629.99 each, making them nearly twice as expensive as our previous hubs. (MiataHubs.com also offers rear hubs starting at $219.99 each.)
As they’re made of steel, they’re also heavier than the aluminum hubs we’re replacing. But we were willing to spend a few pounds–and a few dollars–for a real solution to our problem.
You might notice one other feature of these new hubs: They’re available with ABS tone rings machined as one piece into the hub body for a slight upcharge. This eliminates even more potential failures such as stock tone rings coming loose or having sensor reading faults due to machining issues.
Our Miata doesn’t have ABS, but we’re planning to remedy that shortcoming over the offseason. We’d planned to machine our old hubs to add tone rings but decided we might as well just order them built in to save some time and money later.
Installation only took a few minutes–new brake backing plate bolts are included to make more clearance for the beefy hub, and a spindle bushing is also included to increase the diameter for the larger bearings.
Once we’d torqued them to spec, we crossed “hubs” off our to-do list–hopefully once and for all.
More like this
Comments
11/3/23 11:34 a.m.
Seems like an upgrade worth every penny.
No one wants to be that guy that flags a session because their wheel came loose.
11/3/23 11:42 a.m.
Hopefully you'll be paying enough attention that it doesn't go that far :) The first year I was a mechanic on a Thunderhill 25 team, we went through a lot of hubs. The team didn't quite understand how badly they'd get beaten up. I think we might have lost one wheel, but it's been more than a decade and I forget what happened exactly at 1am.
There are few upgraded hubs available on the market. A budget option is to go to a blueprinted stock unit. That's what we used the second year at Thunderhill, and none of the four cars on our team had a hub failure. There are also modified E30 hubs from Brofab, and Mazda Competition offers an tapered bearing option as well. Two of those choices are available from my favorite Miata vendor :)
NickD MegaDork
11/3/23 11:48 a.m.
I did this on an aftermarket replacement hub at an autocross. Ripped the face of it apart at the top of 2nd gear in a slalom. That was.....thrilling.
Noddaz
Noddaz GRM+ Memberand PowerDork
11/3/23 11:51 a.m.
In reply to NickD :
That is down right scary.
Should I be concerned on a stock street only Miata?  Or just inspect at brake jobs.
11/3/23 11:58 a.m.
The usual concern with Miata front hubs is bearing failure, not so much flange failure. That's why a few of the upgrade options like the Miatahubs run tapered bearings.
But there are a bunch of aftermarket stock replacement hubs with slightly different castings, some of which have proven to be insufficient to the task as they have built-in stress risers. I've seen more rear wheel drive flange failures myself, including one on my own car.
Tom Suddard
11/3/23 12:08 p.m.
Yeah, I'll second what Keith said. OEM hubs are usually fine as far as flanges go, but the bearings don't last very long. But some of the cheap aftermarket replacements can explode like that. That's one reason I replaced every hub on my 350Z with new replacements from the dealer when I had the suspension apart--at 200,000 miles, I wanted to make sure I wasn't racing on the cheapest stuff the previous owner bought at the parts store.
NickD MegaDork
11/3/23 12:51 p.m.
Also didn't help that this is a 250whp car on 245-width Super 200TW tires that gets autocrossed heavily. I may have been exceeding the design expectations just a little bit. I had chewed through a bunch of the bearings and usually just put a set of hubs in the front. That was the first, and only time, that it ever did that. Of course, I had just installed Wilwood calipers on the front and it ground the rotor into one of the brand-new calipers. Fortunately another autocrosser had a spare bearing on hand and we put a wheel bearing in this thing in like 15 minutes and didn't even miss a run.
z31maniac
z31maniac MegaDork
11/3/23 1:26 p.m.
I don't remember the brand FM used to sell, but 10 years ago with my NA, we killed both fancy front hubs in one track day (I was sharing the car with a friend so we it went through like 13 sessions in one day).
Jesse Ransom
11/3/23 2:54 p.m.
What was going on with the loosening hubs? Settling or sinking races? Crazy wear of actual bearing surfaces?
I'm having trouble getting my head around an excess-clearance failure mode that can be even temporarily resolved by adjustment...
fullbeans
fullbeans New Reader
11/3/23 3:09 p.m.
These hubs are great! Within a handful of races, they paid for themselves.
Racing in Champcar, we were losing at least one hub, usually multiple every race. We tried all the vendors for the stock hubs and it didn't  make a difference. All bearing failures.
Haven't had a single failure since we got the MiataHubs hubs. A few races after getting them, I realized how much less stress I felt during the race. Before, I was always waiting for the hub failure, had to be ready to change it at any minute. All that went away.
Sponsored by
V8 Roadsters
JNnl0KaAYhyueXWErVf7llLGzRCEEr57Km2NIXQ6IdWjxdO7k2dhAOEAEl0Emh7u
