Our Turbo Miata Goes Boom
Ed
Update by Ed Higginbotham to the Mazda Miata project car
Mar 21, 2017
Sponsored by
Don't worry, we made sure the road was safe and clean for others after we left our mark.
The smoking gun: All the oil marks in the engine bay appear to point toward the end of this oil hose that leads to the turbocharger.
We're also replacing all the suspension bushings throughout the car with parts from Energy Suspension.
A hydraulic press makes short work of suspension bushings.
We also have to replace our eBay coil-over sleeve setup (right) with stock Miata springs (left).
Racing wouldn’t be racing without constant setbacks. Nobody is immune to failure at some point in time, but if there’s one thing you don’t want to fail two weeks before a race, it’s the engine. See what we’re getting at?
After a flawless endurance race, our project turbo Miata gave out on us with the most inconvenient timing: while being moved between shops during our pre-race prep. That next race takes place in less than two weeks.
What happened? As best as we can tell, the oil line leading to the turbocharger failed and started spewing oil while we were driving the car. Unfortunately, the engine wasn’t hot enough to create an alarming plume of smoke. Just before we reached the second shop, we saw the oil pressure “gauge” drop to zero—remember, this year of the Miata doesn’t feature a proper oil pressure gauge as it’s really just an on/off idiot light connected to a gauge-like display. A few lessons have been learned here.
We immediately killed the engine, but after pushing the car into the shop and topping off the oil, our fears were realized: We still had no oil pressure. Our engine was done.
To confirm that diagnosis, we removed the oil filter and cut it open to see what it had caught. Though not much, there was definite evidence of copper. That was the final nail in the coffin.
Fortunately we’re armed with a backup engine. It’s a stock 1.8-liter from an automatic-equipped donor car. With a few late nights and some elbow grease, we hope to have the engines swapped in time to test the car at the FIRM this weekend.
While we have the car in the air, we are also making a couple suspension adjustments. First, we’re replacing all the suspension bushings with new parts from Energy Suspension. With a little help from a hydraulic press, this is a pretty straightforward (though time-consuming) process once all the control arms have been removed.
After that, we have to replace our eBay coil-over sleeve setup with stock Miata springs. This might be a performance downgrade, but we need to run stock springs in order to avoid incurring penalties at our race with ChumpCar at Daytona. Fortunately we can retain the Koni Shocks we’ve been running.
If everything goes according to plan, the car will be buttoned back up by the end of the week.
Watch the pages of Grassroots Motorsports for the full project car series. Subscriptions start at just $10.
Comments
3/21/17 1:07 p.m.
I can't believe that turbocharger outlasted the engine I run my car with both a proper gauge AND a big warning light hooked to the '96+ 7 psi switch. You can never make low oil pressure too obvious for a driver.
Stainless feed line?
3/21/17 1:13 p.m.
Very true, Keith. And yes, the feed line is a stainless braided line.
Woody
Woody GRM+ Memberand MegaDork
3/21/17 1:14 p.m.
In reply to Keith Tanner:
Tell me more about this 96+ switch that I probably have two of in my basement.
NickD SuperDork
3/21/17 1:14 p.m.
And it didn't even get to go out in a blaze of glory, with connecting rods and chunks of block flying everywhere, just a relatively quiet death.
3/21/17 1:20 p.m.
In reply to NickD:
Yeah, this way may be less exciting, but at least we might be able to salvage most of it and rebuild it.
NickD SuperDork
3/21/17 1:24 p.m.
In reply to Ed Higginbotham:
That is also true. It's just kinda like when you break a bone doing something normal and you don't get a cool story out of it.
appliance_racer
appliance_racer New Reader
3/21/17 1:38 p.m.
I am (was) planning to stop by and say hi at daytona since I will be there wrenching for another team. If you need an extra wrench spinner please contact me. I'll have plenty of spare time and would love to help. Email me if you guys would like my phone#. I live in Orlando.
KyAllroad
KyAllroad UberDork
3/21/17 1:47 p.m.
Sorry to hear about your engine. That reminds me to replace my oil pressure sending unit with one from an NA6.
Of note: I just finished replacing my suspension bushings with the energy poly ones. Don't even try to push them out, you'll just get frustrated. Energy recommends (and I agree) using a torch and heating the old bushings till you hear them crackle but not actually burst into flame and then knocking them out with a punch (I used a 8" extension and a 22mm impact socket). They stink so good to do outside.
APEowner
APEowner GRM+ Memberand Reader
3/21/17 1:52 p.m.
NickD wrote: And it didn't even get to go out in a blaze of glory, with connecting rods and chunks of block flying everywhere, just a relatively quiet death.
If I'm going to loose a race motor I want them to have to clean track the afterwards. This way is less expensive however.
3/21/17 2:06 p.m.
In reply to appliance_racer:
We'll see you there! Thanks for the offer.
Sponsored by
V8 Roadsters
CY5SBQyYYZ1E8GapE0y1gRXtjivjJT0FLV9kv5KSDXWVXPyrbdvR3E7FOPDQHnZz
