Subaru Upgrades On a Budget
Per
Update by Per Schroeder to the Subaru Impreza Wagon project car
Sep 9, 2010
Sponsored by
Some used Rota wheels and Continental ExtremeContact DW tires give our Subaru a little extra dry traction and a lot more wet traction.
The rear bar installs in about 45 minutes.
The stock rear bar is 13mm, while the new one is 20mm. Kartboy end links round out the upgrade.
To give our Subaru a more neutral cornering attitude, we added a 20mm rear anti-roll bar from Whiteline. The bar is a bit thicker than the OE options and has two adjustable settings. To make the most of the bar’s rate, we also upgraded the weak plastic end links with some beautiful aluminum pieces from Kartboy.
We also picked up a set of used 17x7.5-inch Rota alloys for the car. We mounted them up with some Continental ExtremeContact DW tires that were left over from some wet-weather testing. We’ll be seeing how these tires behave under light rallycross action. Judging by the tread pattern, we expect them to grip pretty well laterally (limiting sideways slide) but have issues with longitudinal traction.
Comments
SilverFleet
SilverFleet UltraDork
9/9/10 11:00 a.m.
Looking good! You are making all the right choices ao far. Keep the updates coming!!!
Dusty
Dusty None
6/21/11 2:45 p.m.
I dunno about the 2000 L, but for my 2002 WRX wagon I got a bargain 20mm rear bar from a WRX sedan for forty bucks.
Sponsored by
The Tire Rack
Exedy
Hella
2Hh5SfigV0c7k0Qdyq2wWVqUII0eb3CirbRw9dtl4LAcsVZ7ZRcpEuASAviMdmU9
