Started on Sept. 17 by scannon
2004 Caterham Roadsport SV
20
Engine: 1.8L inline four cylinder, DOHC, 4-valve-per-cylinder engine from a 2000 Mazda Miata, with aftermarket turbocharging. Controls: Hydra stand-alone ECU with Hydramist water/methanol injection. Induction: Mazda Miata intake manifold with 550cc RC fuel injectors. Flyin Miata (Garrett 2650) turbo and exhaust manifold, Track Dog Racing intercooler. Cooling: Caterham double-row, triple-pass aluminum race radiator with one 12” Spal electic fan (pulling). Exhaust: downpipe with divorced wastegate graduates to 3” diameter and flows into a 3” polished side pipe with metal catalytic converter and glass-pack muffler, then divides into two 2” tailpipes. (Designed by owner, and constructed by Hanksville Hot Rods in Littleton CO.) Transmission: 5 speed Miata transmission. The tailshaft was modified for transmission tunnel clearance and to suit Caterham-style transmission mounts. 8.5 lb ACT flywheel, 2005 Mazdaspeed turbo clutch (hydraulically actuated). Custom driveshaft fabricated from a Caterham rear weld yoke and U-joint, and from a Miata splined yoke combined with an RX-7 front weld yoke and U-joint. 2” high strength steel driveshaft tube. Rear axle: the car retains the Caterham deDion rear suspension, with Caterham-supplied British Ford “Sierra” 3.92:1 ratio gears and differential carrier, but with a Quaiffe limited slip differential substituted. Front Susp.: stock double A-arm with Caterham (Bilstein) adjustable coil-over shocks and sway bar. Rear Susp.: deDion semi-independent rear suspension with adjustable coil-over shocks, Watts links on both sides, and an adjustable sway bar. Brakes: Caterham supplied 9” disks on all four wheels, 2-pot calipers on the front, single pot calipers with parking brake on rear. No power assist. The car weighs 1,350 lb wet. Engine is dyno tuned producing 295 RWHP and 260 lb ft of torque. Pictures at: http://www.britishv8.org/Other/SkipCannon.htm
Join Free Join our community to easily find more reader's rides.
Comments
ACarlson
Oct. 2, 2009, 11:45 a.m.
1350 lbs, 295 whp? Yeah, that should just about do it.
grimmelshanks
March 27, 2010, 11:14 p.m.
nice locost
smile468
May 28, 2010, 1:49 a.m.
Milking the Cow For a long time I’ve been doing a drill that I like to call “Milking the Cow.” From the photos, you probably can guess where it got its name. ishiner [url=http://www.golfsetbase.com/blog/the-compare-between-golfwholesale18-and-golfsetbase/]www.golfwholesale18.com[/url] Why is it important to “milk the cow” in your swing? Because it creates a 90º angle between your left arm and your club shaft and, in golf, that’s what we call “lag.”
captslow
Sept. 7, 2010, 2 p.m.
Wow a canoe in the comment section of a cool car... Thats just low...
Add your comment
See more
DMBm0IZm5awyUGXuPv4mOjpjjSHZQ66I3a12Q5rCGiseUo1Vfcb5m56UoxDoqqgI
