Started on Oct. 29 by JRCook320
1981 BMW E21 320i turbo
35
I bought this ‘81 BMW 320i for $650 10 years ago as my first car and it has been a labor of love since, ultimately resulting in an empty shell restoration with lots of upgrades along the way. Chassis modifications include Volvo/girling 4 pot calipers & vented rotors, 323i rear disk conversion, Wilwood proportioning valve, 3.91 LSD, slotted rear subframe, Bilstien sport shocks, Eibach springs, 25/19mm swaybars, front and rear strut braces, welded-in front frame rail brace, 15x7 wheels, lug stud conversion and poly bushings throughout. The motor is stroked to 2.0L with flat top pistons yielding 8:1 compression, I-J crank scraper, mild 280 cam, ported and polished head, Bosch red coil & 8mm plug wires, AC delete, electric fan, 8lb aluminum flywheel and 6 puc clutch. I recently designed and fabricated a budget turbo system using a mix and match of ebay parts from other vehicles. The system consists of a Dinan turbo manifold, T25 from an S13 Nissan Silvia (60 trim .80 AR, internal waste gate), 12” FMIC, 1G DSM BOV, BMW e12 528i 65mm throttle body, Hallman Pro MBC, and home fabbed charge pipes and 2.5” exhaust. I chose to stay with the old school CIS mechanical fuel injection but with some upgrades including a Porsche 931 fuel distributor and air flow meter, Porsche 930 fuel pump, Mercedes Benz 450 SEL 6.9L injectors and VW mk1 injector lines.  The car gets a clean 14.7:1 AFR when cruising and drops to ~12:1 AFR under boost all the way to 7000 rpm. The Ignition is pulled under boost by a Volvo 240 turbo dual port ignition advance canister. The motor currently puts out about 250 hp at 14 lbs of boost.  This is enough to propel the car to a quarter mile of 13.92 @ 100 mph, though at only 2400 lbs it should be capable of a mid 13 if I could drive it.  The car is my daily driver in the summer season and sees occasional autox events and so far 1 track day at Nelson Ledges.  It is a blast to drive! Future upgrades will include larger front rotors from a Mini Cooper, GC coilovers, camber plates, slicks, and a larger 2 core aluminum radiator to cope with the heat of track days. Here’s a few pics of the turbo project build:                              For more pics and info check out my web page and youtube vids: My E21 Web Page E21 Legion: The movement is on
Join Free Join our community to easily find more reader's rides.
Comments
Stuc
Oct. 31, 2008, 10:31 a.m.
Clean!! I love how those BMWs look from the back
peperry
Oct. 31, 2008, 6:48 p.m.
Looking good Josh!
dhlthr
Oct. 31, 2008, 10:21 p.m.
Nice work, a budget car that can fly. Love to see complete write up in your mag.
nicksta43
Nov. 3, 2008, 7:58 p.m.
Great job!!! Thanks 4 making me regret selling mine even more. You where on the old e21 info group weren't you?
jrcook320
Nov. 3, 2008, 11:03 p.m.
thanks guys. I used to be on roadfly and sometimes on 320i.com. I spend most of my time on bimmerforums though.
boostede21
Nov. 4, 2008, 12:04 p.m.
I love Josh's car. The best part is, he does the work himself. Good luck Josh!!
Tim
Baxter
Nov. 4, 2008, 1:37 p.m.
Somewhere around here I still have my bumper sticker from the old e21.net site. Still miss my 320s.
irish44j
Nov. 13, 2008, 1:22 p.m.
beautiful ride!
stereoking15
Dec. 6, 2008, 12:21 a.m.
very impressive, doing what gearheads do best take a bunch of other makes and models car parts and retrofit them to your ride i love it!! very well done just brilliant
jrcook320
Jan. 18, 2009, 7:48 p.m.
Thanks guys. Tim, I recently saw some of your old files on the old yahoo e21 digest. Too bad you sold your e21's but there are obviously many better platforms out there. Anyway, I'm currently selling some unused spare parts to fund slicks and coil overs for the upcoming season.
Add your comment
See more
fLNlO0L80AECbJuXyuyamPQzfBaPGiFUzazY3xhW9E8YlsaKQZIRRNbj5lHed2kr
