Wheels as Wear Items
“Wheels are metal,” Weiss continues. “They’re not magic.”
No matter the construction technique, a wheel in use continuously encounters stresses. Every acceleration, every braking, every turn and every bump adds up to a nonstop barrage of forces.
Then add in the forces encountered every time tires are mounted and dismounted, plus each time the wheels are bolted and unbolted from the hub.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/06/22/1592856189_gsdetailing_mmthumb.JPG)
“Those little impacts continuously work that metal,” Weiss continues. “Then a Big Bang will send it over the edge.”
And that Big Bang can cause a major wheel failure–and often leave a bewildered driver. Did one impact just knock a wheel out of contention? Likely, Weiss explains, it might have been a death from a thousand cuts.
What Stresses Wheels?
Then add in the additional stresses found in motorsports.
Sticky tires? Additional stress.
High g-load turns? Additional stress.
Fast pitstops involving impact tools? Additional stress.
Banging over curbs in order to tighten a turn? Additional stress.
Lower profile tires that minimize the cushion from road hazards? Additional stress.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/06/22/1592856380__8522282_mmthumb.jpg)
“When tracking the car, be conscious that you’re working your wheels really hard,” Weiss says, adding that the load ratings assigned to each wheel are based on a static car. They don’t take into account hanging two wheels in the air. Or curb checking. Or contact with another car.
For a perfect storm, Weiss says, picture the leverage exerted by a tall, sticky slick fitted to a smaller wheel on a powerful drag tire. When the light turns green, the wheels are placed under enormous stress.
How to Inspect Wheels?
“What are you doing to inspect this wheel?” Weiss asks, adding a big take-home message: Be aware that wheels are a wear item–especially when subjected to severe use–and develop some kind of inspection schedule.
That schedule can be rather simple, he continues. For a street car, periodically look over the wheels–say whenever you’re stopping for gas.
Any curb rash? Do the lips look misshapen? Regularly look for obvious signs that hints towards a big impact.
Do you have a second set of wheels and tires for autocross or track events? Take a few minutes to clean and inspect the wheels–front and back–when swapping over.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/06/22/1592856136_img_20191019_180614_mmthumb.jpg)
Photography Credit: Christina Lam
Make that inspection part of the routine. Give the wheels a good wash and take a few minutes for a full visual look-over.
Methodically inspect the entire wheel: lips, barrel, spokes and center section. Are any little cracks manifesting? Do the lug seats still look fresh?
Are you road racing, running stage rallies or tracking a car with a lot of aero? Those situations can put even more stress on the wheel, so maybe perform even deeper inspections on a tighter timeline–again, Weiss stresses, make it part of a routine. The goal, as before, is to spot small issues before they become big ones.
Did you have a big off lately, perhaps one that dragged the wheels sideways across the infield? Rub wheels against those from another car while going side to side? Encounter a rougher than usual rally stage? Again, inspect the wheels–and this time, ideally, do it as soon as possible.
Two relatively easy ways to make a deeper inspection: DIY crack testing can be done at home with a dye penetrant kit, while a bare wheel can always be checked on a balancer. The unmounted wheels likely won’t spec out to zero, Weiss notes, but if it’s calling for a lot of weight, you might have a problem that warrants further inspection.
“Don’t treat them as a set-it-and-forget-it-type of part,” Weiss says of wheels. Be conscious of their use and keep a regular eye on them.
