So, one day, I'm messing with the truck, and I hear a high pitched squeal coming from the dash. I proceed to rip all the buzzers out, but it continues. Intermittently. I pull the dash apart for the 9th or tenth time in this project, removing things, and replacing them once the squeal comes back. Heck, the squeal even started a couple of times while the engine wasn't running. I was pulling some box with wires going to it behind the glove box when, by chance, I hit something. The pitch changed. Keep in mind the mosquitoes, and realize the noise had me going a little batty by this point, so when I hit the vacuum hose on a dashpot that did something or the other with the HVAC, I was really ready for a win.
This truck has been wrecked. A lot. Not by my brother, nor myself, but lots of other people. The Carfax actually says "JUNK", not salvage, rebuilt, or anything like that, but JUNK. The condenser was toast. AC hadn't worked in years. The heat worked, but not really out the vent you had it set for. So, in light of all those things, plus the fact that the included grill -Thanks, Bro, wouldn't fit with it on, The Ac got (partially) aborted. I put a ball valve in the heater line to the core, and proceeded to remove all that vacuum actuated (ha!) HVAC stuff, Zip tying, gluing, taping, and generally using any means necessary to ditch all vacuum controls. See a trend here? Crappy computer-bypass, Crappy heater controls-Bypass.Cruise doesn't work? Abort.
So, some more pics are in order. I wanted to use the included aluminum wheels-Thanks, Bro. Like a jerk, I forgot to take pics of the oven cleaner, wire wheel, priming and clear coating stage,so we'll skip right to some overall pics. Note also cheap mirrors welded to the body-Classy...
Those are some MILESTAR Radial SL369s in a LT 235/85/R16 if you were wondering. Brand spankin, too. Try to stifle your gasps of amazement.
Note the snazzy included grill-Thanks, Bro, which took a crap load of cutting, hammering, and swearing to fit. I had to lower the headlights some 2". and cut the core support a good bit, as well as the aforementioned condenser removal, and a little off the valence. Then it fit! Not too well, and I wouldn't exactly call the headlights "level", but they are aimed well.
Also, Yes, I admit it, I am rusting this thing on purpose. It just sort of happened.
Those with sharper eyes may have already seen the chrome acorn nuts I put down the center of the hood. Here's a better shot;
Other projects patiently awaiting their turn;
And more of the same;
...Aaand, finally, a teaser for the next installment;
And look-a-there, editor- You could see this "foreshadowing" exhaust shot a few back if you look. Learning is fun.
