I have never been in a position to replace an auto with a manual or visa versa. All of the autos I have owned have swapped with other autos and ditto for the manuals.
Where am I going with this?
Read this: http://grassrootsmotorsports.com/forum/off-topic-discussion/help-need-to-discuss-dd-replacement-quickly/37073/page1
Yeah. That's my thought. Let's have a thought experiment, the engine is a Duratec 3.0 V6, the transmission is the CVT.
Bolt it up:
I don't know what's common between the 2.5, but wikipedia makes them sound like the same engine with a different bore. The bad part is this line "A slightly modified version for the Ford Five Hundred entered production..." - a 500 is basically the same drivetrain as the Freestyle. I wonder what slightly means. Does anyone have any idea what manual transmissions which bolt to that engine that would be "good"? According to wikipedia again, the list of cars is:
Jaguar S-Type
Lincoln LS
Mazda MPV
Mazda 6
Mondeo ST220
I think all of those save the MPV had a manual transmission option, but the LS is RWD.
The 2.5 has:
Ford Mondeo
Mercury Cougar
Mercury Mystique
Jaguar X-Type
All of which (I think) had a manual option.
So, does anyone know which of these options sounds like a good plan, physically?
Wire it up: The freestyle has an electronic throttle body. It won't even let you rev it past 3.5K in neutral and only slowly at that, so I know it's watching the transmission and the Freestyle isn't available with anything else. Any Ford engineers here? Is it a resistor I have to apply across pins x and y to trick the ECU in to thinking there is a tranny ECU which is perfectly happy and in drive, or is there a crazy PWM signal that's VIN specific and rotating frequency?
Control it:
Pedal assembly for a hydraulic clutch from Tilton? Ford Mondeo pedal assembly? I know it's going to require fab work for a pedal, but can it be that bad?
Spin the wheels:
Tranny width vs axle length? Spline counts? Anything like that?
A thought experiment, yes, but I don't think there is any group of people anywhere who could actually think this through rather than tell me I am nuts.
Oh, and don't bother to tell me that I'm nuts... please. No naysaying unless you bring data.
