RacetruckRon
RacetruckRon GRM+ Memberand HalfDork
6/2/20 4:23 p.m.
These greasy and corroded aluminum parts are the hardware for the rear leaf spring on my Corvette/minitruck hybrid love child.  I thought there was a thread on this or mentions of this recently but I can't seem to find it.  What is the hives preferred means of removing aluminum corrosion?  Do I just hit them with the wire wheel and 3m abrasive pads or is there a chemical route that works better and doesn't remove as much material?
EvanB (Forum Supporter)
EvanB (Forum Supporter) GRM+ Memberand MegaDork
6/2/20 5:02 p.m.
You could try an acid aluminum brightener like zep alume or alumabright.
RacetruckRon
6/2/20 6:35 p.m.
Thanks I'll look into those.
Woody
Woody GRM+ Memberand MegaDork
6/2/20 6:43 p.m.
Makes the diamond plate on old firetrucks shine like new.
lotusseven7 (Forum Supporter)
lotusseven7 (Forum Supporter) Reader
6/2/20 7:20 p.m.
Someone told me that Easy-Off oven cleaner works, but I've never tried it myself. Maybe others will know better.
djsilver (Forum Supporter)
djsilver (Forum Supporter) Reader
6/2/20 9:12 p.m.
Don't do it.  I tried it and it cleaned the grease and oil away, but the aluminum had little dots of white oxidation stuff blooming out of the parent metal for a long time.  Aluminum will dissolve in either high pH or low pH solutions.
stuart in mn
stuart in mn MegaDork
6/2/20 9:18 p.m.
NAPA sells an aluminum brightener that works well.  It is an acid, so be careful.  It's also not meant for polished surfaces.  https://www.napaonline.com/en/p/MCR1458
Apexcarver
Apexcarver UltimaDork
6/2/20 9:29 p.m.
Read the MSDS on that stuff before you buy. I'm surprised you can buy that without some equally strong paperwork.
Now, where can I get some?
pirate
pirate HalfDork
6/2/20 10:53 p.m.
Media blasting with glass beads will make parts look like new. Eagle One sold at most pats stores has a product call Eagle One Magnesium Cleaner and Etch which does a retry good job. Make sure to wear rubber gloves and eye protection,
Tyler H (Forum Supporter)
Tyler H (Forum Supporter) GRM+ Memberand UberDork
6/3/20 9:23 a.m.
^Agree with media blasting.  Depending on how pretty you want it, you could clean it up and powder coat them in 'bright aluminum.'
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) Dork
6/3/20 9:38 a.m.
Ditto on glass bead unless you want to try and weld it after, the beads can inbed and cause issues.
RacetruckRon
6/3/20 9:46 a.m.
Media blasting would of course be the best choice but I don't have a blast cabinet or even room for one.  I might just have to try that NAPA spray and some elbow grease.
pirate
pirate HalfDork
6/3/20 11:22 a.m.
If you have someone who powder coats or a small fab shop they might be able to media blast your parts for minimal cost.
6/3/20 11:56 a.m.
Good advice here.  I don't have a blast cabinet because they're a mess and take up a lot of floor space.  I've had really good luck dropping parts off to get blasted affordably.
Woody
6/3/20 1:31 p.m.
Oh, we're all about MSDS sheets at the firehouse. And I suppose as a municipality, we do have access to equally strong paperwork.
But, yeah...don't use it on your lawn.
stuart in mn
6/3/20 4:05 p.m.
Media blasting isn't always the best choice.  Aluminum brightener (like the NAPA stuff I posted earlier) won't affect the texture, and if you don't have free access to a blasting cabinet it will be easier and less expensive.
6/3/20 7:23 p.m.
If you want it media blasted, stick it in a small box and send it to me in PA, I'll do it and send it back.
mikeatrpi
mikeatrpi HalfDork
6/3/20 8:18 p.m.
Another vote for eagle one mag wheel cleaner
jwagner (Forum Supporter)
jwagner (Forum Supporter) Reader
6/3/20 10:40 p.m.
Do you have a DIY blasting place near you?  That looks like about fifteen minutes worth of cabinet rental.
ebelements
ebelements Reader
6/4/20 11:09 a.m.
Any reason why a rotary tool with a brass wire wheel would be a poor choice, say, if someone didn't have access to a blaster?
Greg Smith (Forum Supporter)
Greg Smith (Forum Supporter) Dork
6/4/20 1:54 p.m.
Scotchbrite pads and aluminum cleaner?
Rusnak_322
Rusnak_322 Dork
6/4/20 2:31 p.m.
you can soda blast them for just about free if you have even a small air compressor.
Here are some before and after pics of some motorcycle carbs I did using baking soda from the basement fridge and a home made blast gun made from a air gun that came in a Harbor Freight air compressor accessory kit.
No cabinet - just wear a good mask and goggles and do it outside.
D1UaiMXqsW3EJVhij9HGygar9BGhITRy0L16w3jqDrLTdib3fCl5iYidAK3VRPJO
