Some Garage Time
Per
Update by Per Schroeder to the LeGrand Mk 18 project car
Oct 27, 2011
Sponsored by
Our LeGrand is up on a jack and blocks, getting some little tweaks.
We replaced the 5w30 oil with some 10w40—and we also removed our oil cooler to reduce weight—the former should help make up for the latter—which isn't all that necessary for Solo use.
Next up, we need to replace our wheel studs with some longer racing pieces.
A new molded seat is in the works for our co-driver.
Even with Nationals behind us, we’re still working on making the LeGrand faster and more reliable.
Even with Nationals behind us, we’re still working on making the LeGrand faster and more reliable. We spent a few hours this weekend changing the oil, this time to Brad Penn’s racing 10w30 and continuing our work on a new foam BSCI seat for our co-driver. We also changed our gearing again—this time we reinstalled the 13-tooth front sprocket. We’re thinking it may be faster to carry third gear more, rather than constantly banging up against the rev limiter in second gear.
The gearing change seemed to help some with ‘out of the hole’ acceleration at our next local event, but the course wasn’t fast enough to take advantage of the now-short third gear. You can see video of that event below.
Next up, we’re thinking about removing our rear anti-roll bar to allow the inside wheel to stay on the ground better—we are getting some wheelspin from the Wavetrac helical differential. An added plus is that we could lose another 6 or 7 pounds with the removal of the bar.
Comments
alfadriver
alfadriver UltimaDork
10/27/11 2:46 p.m.
Is the course that bumpy, or does the engine start acting funny the faster you go?
Per Schroeder
Per Schroeder PowerDork
10/27/11 3:18 p.m.
It's amazing what little bumps do to a lightweight/high hp car. I'm hoping that getting rid of the rear anti-roll bar helps droop travel and stops some of that.
DaewooOfDeath
DaewooOfDeath Dork
10/27/11 10:33 p.m.
It seems like a car that small and that low wouldn't need much to control roll. Have you tried a tiny bar in front and nothing in the back?
Per Schroeder
10/28/11 9:39 a.m.
It still needs a front bar---but the rear has been removed and I'm waiting for the next event or two to see if that helps. Part of the choppiness that Alfadriver notes is actually my/foot leg bouncing on the gas pedal--something I'm still working on controlling at lower speeds. Other drivers use stirrups to keep their legs from moving too much.
p_matt
p_matt
10/28/11 10:32 a.m.
Stirrups, Giddyup!!
fifty
fifty HalfDork
10/29/11 1:15 p.m.
Is that an iPhone on the dash, and if so, what datalogging software are you running?
Per Schroeder
10/31/11 9:01 a.m.
I'm trying out Harry's lap timer.
nmscot
nmscot New Reader
10/31/11 7:11 p.m.
I use to live in FLA back in the 70' and did some autocrossing -- where is that site?
Per Schroeder
10/31/11 8:32 p.m.
Orange County Convention Center-- new-to-SCCA lot.
motomoron
motomoron SuperDork
10/31/11 9:25 p.m.
I have to drag the side of my shoe on the chassis skin of the footwell when I'm driving the Radical in the paddock or it can get all choppy and messy and bucking and whatnot, mighty quickly.
BTW - I'm buying a set of 25s next year and trying B mod.
Sponsored by
GRM Ad Dept
iGFzCT7cPbhvwWJFRBpPH7lENtCUVyE1jXFGPZerlzYnKXlTX29eoPVFLeD2MgoX
