What separates street brakes from racing brakes?
David S.
By David S. Wallens
Oct 30, 2024 | Ford, Endurance Racing, brakes, Ford GT | Posted in Suspension & Handling , Safety | From the Aug. 2020 issue | Never miss an article
Photograph Courtesy Ford
Similar cars. Different missions. Very different equipment.
The brakes for both the road and race versions of the latest Ford GT are supplied by the same company, but their specs vary. Greatly.
The street car’s brakes must perform at a high level while also remaining civil—no noise, no discomfort. The ones on the race car have a narrower purpose: to help win races. Both operate on the simple premise of converting kinetic energy into heat, but parsing how each one meets its specific engineering challenges is a deeper dive than you might imagine.
Street Brakes
Even a machine as exotic as the latest Ford GT—the brand’s half-million-dollar, 660-horsepower supercar—is still primarily designed for street use. It’s fast, yes, “but 99% of the time, it is a road car,” notes Benjamin Pohl, Brembo North America’s senior program manager for original equipment. “Noise, wear, dust: Consumers care a lot about those things.”
How the brakes feel is also very important to the end user, he continues: “They don’t want to feel brake judder on their drive to work.”
At the same time, these brakes must be able to handle track use that Pohl characterizes as short-duration, limited and nonprofessional—basically a track day, with drivers tapping maybe 80% of the car’s capability.
Brake photograph courtesy Brembo, GT photograph courtesy Ford
1. Pad Life
The 10mm-thick pads found at the front of the street Ford GT should last 30,000–40,000 miles, according to our source at Brembo.
2. Piston Size
Both the race and street brake calipers feature six pistons up front and four pistons out back. Piston size differs, though. Federal regulations state that, should the power assist fail, the street car still must slow at a certain rate at a certain pedal pressure. That typically dictates larger pistons.
3. Anti-Rattle Clips
The street calipers get anti-rattle clips to keep things quieter and control the retraction of the pad.
4. Caliper Life
A street caliper is designed to deliver hundreds of thousands of cycles over years of service, in some cases the entire life of the vehicle. “That might drive a caliper to be heavier,” Pohl says. In this case, a cast-aluminum caliper met the cost and operational goals.
5. Caliper Seals
As the pads wear, rubber accordion dust boots keep foreign debris off the caliper pistons.
6. ABS
The street Ford GT, like every other road-going vehicle sold today, features ABS.
7. Rotors
The production version of the Ford GT fills its 20-inch wheels with two-piece carbon ceramic brake rotors: 394×36mm fronts, 360×28mm rears. According to Brembo, these rotors weigh 50% less than traditional cast-iron pieces.
8. Friction Material
The pads must operate under a wide range of temperatures while remaining quiet, civil and relatively dust-free. Federal standards are currently phasing out copper and other heavy metals from brake pads.
9. Weight
A fully loaded, cast-aluminum front caliper for the street Ford GT weighs about 16 pounds. “Racing guys have the opportunity to remove weight where we can’t,” says Pohl.
10. Cooling
The road car is one of the few street models delivered from the factory with caliper ducts.
11. Cost
Ford initially promised to build 1000 copies of the Ford GT over four model years. “Even 250 units per year, that’s a lot of units,” explains Pohl. “We have to design a caliper for high-volume manufacturing.”
Brake Issues?
“Nine times out of 10, it comes back to cooling,” explains Mike Messina, manager of racing at Brembo North America. “Take whatever you think you need and double it.”
Racing Brakes
The factory-backed Ford GT race effort landed with a splash, winning big at its Le Mans debut in 2016 as part of a 1-3-4 finish. Then the success came stateside, with class wins at Daytona for 2017 and 2018.
“We have more freedom to make exactly what is needed for the intended use,” explains Mike Messina, manager of racing at Brembo North America. “In some ways it’s easier. I don’t have to worry about how loud it is.”
Brembo’s only mission when creating the brakes for the race car? Winning races. Any other concern, including cost, was secondary. Messina used a tire analogy to explain these brakes: “We’re making racing slicks.”
Brake photograph courtesy Brembo, GT race rar photograph courtesy Ford
1. Pad Life
The front calipers are built around 30mm-thick pads, enough material for 18 to 20 hours at Daytona. Some teams have run all 24 hours at Le Mans on a single set of pads. “I don’t recommend it,” says Messina, “but it’s been done.” Each 1mm in pad width requires 2mm in caliper width. “All of this adds up,” Messina continues, noting that a race caliper can wind up being considerably wider than its road-going counterpart.
2. Piston Size
Racing calipers tend to feature smaller-diameter pistons, as these yield more driver control. “Drivers like to feel something that’s very mechanical,” explains Messina.
The race car doesn’t get these.
4. Caliper Life
Race calipers are rebuilt between races.
5. Caliper Seals
The street car’s accordion seals would melt under competition conditions, so the race calipers just get a primary seal.
6. ABS
No ABS for the race car.
7. Rotors
The IMSA and WEC homologation specs for the race car call the shots here, requiring 18-inch wheels and cast-iron rotors: 380×35mm fronts, 355×32mm rears. As on the street car, the two-piece rotors feature an aluminum center hat.
On track, the brakes operate within a narrow temperature window and don’t need to bother with street manners. “The race car can be so much more focused on a narrow range of operations,” says Messina. “Most race pads don’t wake up until 300 degrees Celsius.”
9. Weight
Thanks to the five-axis machining work, which adds to the manufacturing cost, the front calipers for the race version of the Ford GT weigh 7.25 pounds.
10. Cooling
“So much attention paid to cooling on the road car helped the race car,” explains Messina. “In the case of the Ford, it was a pretty straight shot. All we had to do was adapt what was there on the road car.”
11. Cost
Brembo says that the race caliper would retail for three to five times as much as the street caliper.
Like what you're reading? We rely on your financial support. For as little as $3, you can support Grassroots Motorsports by becoming a Patron today.
Join Free Join our community to easily find more Ford, Endurance Racing, brakes and Ford GT articles.
Comments
300zxfreak
300zxfreak Reader
8/4/20 10:20 a.m.
Ford GT at a track day, you must be kidding. Only if it was enclosed in a plastic bubble with land mines around it. Ford could have fudged on the engineering since none of these things actually get driven. These are strictly investment grade jewelry. That said, I love them and the GT40 before them.
wspohn
wspohn SuperDork
8/4/20 10:28 a.m.
Interesting article, thanks.  I think that racing practice has improved street brakes in many cases. If Jaguar hadn't been running Le Mans they probably wouldn't have gone to discs as early as they did.
There are many cars made with perfectly adequate braking systems  but owners insist on changing them out for something larger, more colourful and most important fo many, praiseworthy in the eyes of their peers when nothing was needed  Some of them try and rationalize it by starting with older half thrashed ill maintained stock systems that they toss out and install new big brake kits and say that the huge difference proves they needed them, despite the fact that in many cases if they had first maintained their stock system and chosen optimal pads, there would have been little difference in the end result.
Nothing at all wrong with fitting stuff to your car for no other reason than you think it is neat - big brakes, alloy wheels etc. etc.  Not sure what the deal with the self deluding need to justify that sort of mod as being a safety necessity is all about.
In the old days, there were a bunch of cars manufactured with crap braking systems - take a look at the first discs used on the front of a Cooper S (I laugh every time I see one) or the rotors they had in the Tiger (wonder who said 'Why don't we make a pocket Cobra out of an Alpine by sticking a V8 in it, but lets stick with 13" wheels so we can't fit a competent brake in there for anyone that actually drives hard")
Tyler H (Forum Supporter)
Tyler H (Forum Supporter) GRM+ Memberand UberDork
8/4/20 11:34 a.m.
Agree.  I think you just summed up a wide swath of the aftermarket industry these days, not just brakes.
1/4/22 3:54 p.m.
Brakes are the #1 issue by a wide margin though, so many people think they need more braking power when they really just need more brake heat capacity/brake cooling. Fancy brake upgrades are a great way to end up with increased unsprung weight and/or a severely lightened wallet (up-front and ongoing, hello race-grade consumables!), while more aggressive pads, good fluid and a cheap brake vent system on a factory all-around disc setup can do the job just as well on most any car that retailed for under 6 digits in the first place.
LanEvo
LanEvo GRM+ Memberand Dork
1/4/22 4:38 p.m.
I've been building and racing an old Mercedes 16-valve for some 10 years now. So, I'm one of the few guys with real-world experience driving this platform pretty hard on the track. I've done ok for myself considering my modest skill and budget (regional champion twice; national champion this year).
There's a growing interest in tracking the 16-valve with a bunch of builds starting on various forums and FB groups. Every single one is obsessed with brake upgrades: 400E 4-pistons, 500E Brembos, Porsche kits, and others. Every thread is "which big brakes do I need for XYZ application" etc.
Meanwhile, I'm here quietly collecting class wins on stock single-piston sliding calipers with just upgraded pads (Raybestos ST-43) and fluid (Prospeed RS683). That setup lets me use lighter, cheaper 15" wheels and tires instead of "upgrading" to 17" for no reason. No one seems to believe this is possible.
1/5/22 10:15 a.m.
Glad you all enjoyed the piece. It was informative to put together.
Thanks.
MockingbirdRacing
MockingbirdRacing
2/2/23 2:59 p.m.
In reply to GameboyRMH : One of my joys in life is seeing a car with a big break kit running on discount all seasons at track day. I do give 'em bit of a head start though.
Tom1200
Tom1200 UberDork
2/2/23 3:25 p.m.
In reply to LanEvo :
My solution was using the ubiquitous Datsun 280ZX upgrade for the 1200 (used on 510s & 1200s). I allows me to use commonly available street pads.
The caliper and disk add 3lbs of unsprung weight but I get that back because the Hoosier bias ply is 4lbs lighter than a radial tire.
I went with the bigger brakes because the are more available and I left foot brake which puts a ton of heat in the brakes.
frenchyd
frenchyd MegaDork
2/2/23 3:48 p.m.
Elkhart Lake with its 3 long straights followed by tight 90 degree or tighter corners and a total of 14 corners  in 4 miles of race track tends to be the exception.   Well and Watkins Glen,  to a small degree Road Atlanta.
  Especially big Fast cars like Corvettes and Jaguars.
    Cars at the sharp end of the SVRA group 6  grid are making 650+ horsepower.  200-250 horsepower more than Back in the day. Original calipers were Iron.  Just replacing them with aftermarket saves 35-40 pounds. Not to mention more effective cooling.
racerfink
racerfink UberDork
2/2/23 4:01 p.m.
In reply to 300zxfreak :
I posted a thread here (with a pic) about a Chin track day at Sebring about a year ago.  One guy there had a Ford GT, two Pagani's, and a FIA GT-3 spec Lambo Hurrican. He did spend more time in the Lambo, but he took all of them out at least twice.
6xZSyXzNGHUKpTwapD1hpAfCQGEAgtR3CP0dgtcMwHhHHqYMnJFcyXWN8oJu0iI1
