dean1484
5/21/15 9:02 a.m.
EDIT 2016-07-09 SOLD
Edit 2016-05-14
Put it up on craigs list this morning but I would really like to see it go to someone here.
Link to add
EDIT 2016-01-04
Bringing this back from the dead as the deal for the Mustang appears to have fallen through.
New Price of $1,200 for the Mustang only. The Expedition has moved on.
I will entertain trades and cash. I need the steel rear bumper for my 2003 H2, I also need a driver's side fender for my Xtype Paint Code MDZ. But I really like cash!!!
Car is Located in Maynard MA
Figured I would post up here first.
My car I have had it since 2000.
1994 Mustang. V6 3.8, AC, rear defog . No power anything.
The back story: I got it for my wife in 2000. It came with a Vortech supercharged V6 that was tired but still ran ok. My wife drove it for about 6 months but did not like the supercharger and with the motor being tired (virtually no compression and low oil pressure) it was time for a new motor. So I replaced it with a V6 from a 1997 with 42K on it. With the replacement motor my wife drove it but she only had a 1 mile commute to work and would on most days walk to work. So the car accumulated very little millage while we have had it. It had 129K when I purchased it and it now has 159K.
Fast forward to the fall of 2012 and it needed intake gaskets replaced. The intake gaskets on these are a known problem and when they fail coolant gets sucked in to the motor and pop the head gasket so instead of risking things I just decided to do a complete top end gasket replacement on the motor. While I was in there I had the heads decked at the local machine shop and some minor cleaning up of the casting slag in the ports (not a true porting of the heads at all). I used Felpro top end gasket set and new stretch bolts. I got it all back together and drove it for a month as my commuter to make sure everything was ok and it was. The car sat all of 2013 after I fixed it. I got the car inspected in February 2014 and at that time I replaced the front tires with new ones. It then has sat did not used at all from February 2014 until now. This car has always been the one I kept around to go to the parts store when our “real” cars need work. But with my wife and I both getting newer cars and us having 5 other cars to drive the Mustang just has not been driven. I have started it several times and every now and then put a battery tender on it but it never needs it. It holds a charge and will start rite up even after sitting for 3-4 months at a time.
Fast forward to a month ago and I was looking at cars and shuffling the fleet around and I realized that the inspection sticker had expired 3 months ago and I realized that it was time to move this car down the road.
Currently the car has the stock 15” rims on it. I have a set of 16” rims from a GT with wide tires on them (don’t remember the size at the moment). The tires were summer performance tires of some sort. They have been in storage in my shed for 4-5 years so they may be junk but they go with the car.
Repairs done in 2010-2013.
  • All brake lines replaced (hard and soft)
  • Radiator
  • Alternator
  • Starter
  • Battery (HD yellow one from AutoZone)
  • Front tires (less then 200 miles on them)
  • Rear Calipers
  • front and rear pads
  • rear rotors
  • New belts and hoses
  • Heater core (It was not needed I later found out I had a leak in the Rad that I could not see)
  • Inner and outer tie rods replaced
  • Shift cable replaced (still needs adjustment just never got to it)
  • Plugs
  • Wires
  • Coil
  • Gas Tank & Straps (more on this in a moment)
  • Fuel Pump
  • Adaptor pipe to plumb the V6 to a GT duel exhaust system.
Interior
Interior is in very good shape for it age. Typical light brown microfiber interior with black trim. No rips tears or stains. Just dated and a bit dusty. Steering wheel is aging due to sun. It is dry rotted and the rubber grip has separated from the inner metal ring When the gas tank was replaced I found some rust/rot up behind the rear bumper. The OE tank straps were rusted and they replaced with aftermarket straps.
Exterior
Exterior is a 4/10. Dark green in color. No body rot that I know of there are a couple very small areas of surface rust. The clear coat is pealing and looks like junk. There are numerous little chips and some scrapes on the front of the car. It does not look like Junk but it is definitely in need of attention if you care about that kind of thing.
The car has a Roush rear wing and a Roush Front fascia / bumper cover. In my opinion it loos a bit dated in terms of style but others may love it. I think they are poser parts not really functional but I got the car with them on it.
The car does have a duel exaust from a GT on it that actually sounds pretty good, (as good as a V6 can sound)
The fake plastic brake duct scoop behind the rear passenger door is broken. I have a replacement that goes with the car.
Issues I know about.
Ebrake works but not well. I have spent hours trying to figure it out. New pads, lines, cables rotors and nothing seems to make it work as well as it should.
The speedometer works when it wants to. I always use Garman GPS so it was never an issue.
Steering feels a little sticky some times. Don’t know if it needs a rack or if it is the PS pump.
The coolant temp sensor was replaced when I did the HG. I think the one I put in is no good as the car runs better with it un plugged. Or it could be a wire or something. I never looked at it I just un pluged it and it ran fine.
Exterior Paint as noted above needs to be re painted.
SRS system has been disabled. IE the air bags are NOT working in the car. The reason for this is that the sensors in the front failed and they are a one year only part that is NLA. The SRS module has been disconnected and the SRS light on the dash hotwired so it comes on at initial start up. SO it looks like everything is normal but again the SRS system in the car is NOT working.
I am asking $1,750 for it. But I will listen to offers as I really just want it gone. I will be putting the $$$$ towards our family vacation this summer. This car has been a good car for us. It has been part of the family for 15 years but it is time for it to move on to someone else and hopefully live on.
I will be giving the car a bath this weekend and will take photos of it and post them up. At the moment it is covered in pollen and dust and what not. At the moment it has that abandoned vehicle look.
Mijivey
Mijivey New Reader
6/6/15 9:47 p.m.
Dean1484....Hello, do you by chance still have the Vortech?
dean1484
6/7/15 12:17 p.m.
Ya but in a million pieces when it let go.
dean1484
6/7/15 12:18 p.m.
No takers? How about $1250???? Anyone? It is just taking up space in my yard.. . . . Ok I said I would get Photos. I am going to do that NOW.
dean1484
6/7/15 12:47 p.m.
Cooper_Tired
Cooper_Tired Reader
6/7/15 4:14 p.m.
The fascia is Saleen,not Roush. And that wing is Steeda I think.
Good luck with sale. It's a hell of a deal
dean1484
6/7/15 10:49 p.m.
I am just tired of it. Don't use it so it is time move it along to some one that will. It is far from perfect (It is after all 21 years old) and used as a DD but it is what I like to call and "honest" car. I think the price is fare for what it is.
dean1484
7/13/15 4:24 p.m.
Anyone? Offers considered I want this gone or it will go to "Kars for Kids"
Ohya and the Expedition in the background of one of the photos is "for sale" as well. That one is a parts car / truck at this point. I drve it last week for the first time in about a month and iut really is not road worthy. The brakes are sketchy at best. They don't have the ford out you through the windshield with your big toe feel anymore. Could be from sitting for about a month. But it did start rite up after sitting. I think it had a new battery last fall. A yellow top Autozone if I remember. Those are the better quality ones they sell with about 100 more CCA than the standard ones. The ABS controller thing on top of the abs pump died a while back (stuck on) so I cut the wires to it to keep it from killing the battery. The brakes were fine after I did this. Motor and trans are excellent (178K) I have been religious about oil changes ever 3K or every spring and fall as my wife drove it for a couple years and only puts 2K a year on it. Junk yard offered $150 (they have about a dozen of them at the moment and they don't really want anther). This thing has rust and even through I can do MA inspections (Yes you can legally inspect your own car) I can not in good faith put a sticker on it. There are holes through the bottom of the doors in to the passenger cabin. This is a MA fail.
Ohya I forgot it has a cherry bomb type muffler on it so it is has a nice sound. .. . . Kind of like a suppermodified. .. .LOL
Lets see.. . Rear end was serviced by me 2 years ago and was in great shape. I replaced all the axle seals at that time. Has 3rd row seat. Grey interior.
I was actually thinking of taking the motor from the truck and putting it in the mustang but that involves replacement of the K member in the mustang I think as my mustang has the early K member that will accept a 5.0 not the 4.6
But if some one wants an interesting project for a challenge car I will let both go for VERY short $$$$$ especially if it is for a challenge build motor swap.
The Expedition is registered until October the Mustang as I sated before is already off the road.
dean1484
7/13/15 4:26 p.m.
New price $1000 If you take both vehicles
dean1484
7/29/15 12:38 p.m.
Bump so someone can find it (link freezing my browser)
Quasi Mofo
Quasi Mofo GRM+ Memberand MegaDork
8/7/15 6:42 a.m.
Hmmm. Bump for now.
dean1484
8/7/15 11:34 a.m.
Please make it go away I am more than likely going to donate the Expedition to charity. Scrap value at the moment is way down so not really worth going that rout.
Cooper_Tired
Cooper_Tired Reader
8/7/15 11:56 a.m.
How much for just the mustang? Does it still run? Where is it located?
dean1484
8/7/15 12:16 p.m.
Cooper_Tired wrote: How much for just the mustang? Does it still run? Where is it located?
dean1484 wrote: No takers? How about $1250???? Anyone? It is just taking up space in my yard.. . . . Ok I said I would get Photos. I am going to do that NOW.
I quoted my self above re the price. Runs fine I have not started it in a month or so however it always starts even after sitting for 2-3 months. When I had it registered it was the car I kep around to be able to get to the parts store when I was working on my other cars. I am going to move it and wash it this weekend so I can get better photos of it and put it on CL. Everything you need to know about it is covered in the first post of mine. If you have any other questions let me know I want this gone.
Quasi Mofo
8/7/15 3:16 p.m.
I know it's somewhere but I'm far too lazy... Where?
Quasi Mofo
8/7/15 3:23 p.m.
Maynard, MA? A 13 hour drive...
dean1484
8/7/15 9:57 p.m.
In reply to Quasi Mofo:
Sorry yes in Maynard ma. I would not be afrade to drive it 13 hours. Obviously nothing I a guaranty but there really is nothing I can think of that I would worry about.
dean1484
8/7/15 10:05 p.m.
Any offer will be considered. I would like to see it live on but it would also be a decent parts car.
Or a challenge car. There are some improved shocks in it but I don't remember what they are. The frount brakes are upgraded to duel piston ones from a later GT. 97 I think? Not sure on that I could look it up I have a list of the mods that the previous owner made.
Don't know if I mentioned it but the alternator was replaced when I did the head gaskets.
Basically it is an old looking mustang that is not perfect but just about all of the mechanical bits have been replaced in the last three or four years so it has some life still in it.
Quasi Mofo
8/8/15 6:35 a.m.
What I need is an SN95 parts car. The price is right. I need to decide if I can deal with a 26 hour trip...
Quasi Mofo
8/9/15 9:04 a.m.
269 two zero three 6403
dean1484
8/9/15 4:34 p.m.
Just saw this I have been out working on the house all weekend when is a good time to call?
dean1484
8/9/15 4:37 p.m.
or test me 339 222 two zero zero three. I will be on line tonight on the PS3 with the GRM GT6 group starting at 8:00 eastern or so.
Quasi Mofo
8/9/15 5:40 p.m.
PS3? Lol, I'm shopping for a rat beater Muffedstain... I ain't got that kinda money
dean1484
8/11/15 11:23 p.m.
Deal all but closed with Quasi. Some paperwork and $$$ need to move around but as of now he has first right of refusal.
tdrrally
tdrrally New Reader
8/12/15 2:17 p.m.
like it do you need a 4x4 tahoe?
WFqdiiNNHriPx1o2xHhlEm19xZSKTS3FFyKVFZ4EgLfMFlexl6x5D0iOGgoYEpkw
