1 ... 4 5 6 7
TheV8Kid
TheV8Kid Dork
10/20/21 11:10 a.m.
Keep at it bud!!! We want to see this car at the event!!
Floating Doc (Forum Supporter) GRM+ Memberand PowerDork
10/20/21 4:10 p.m.
Somehow I missed this thread. I read through the whole thing today. Looking forward to seeing it there.
RacetruckRon
RacetruckRon GRM+ Memberand Dork
10/20/21 5:17 p.m.
I can't believe I never saw this thread until the sale post. I'm very interested in it as a roller and would like to look through your broken ls parts pile. Best of luck at the challenge this weekend.
cruisermatt
cruisermatt Reader
10/20/21 10:47 p.m.
We were pretty exhausted after getting the van motor pulled and getting the van body back on the frame, it was about 1pm at that point, neither of us had slept really since the night before. Dale had to work and i was wiped so i went home, took a nap, came back with other teamate Derek and we got the motor and trans in and cleaned up most of the giant atf/oil spill.
ill come in early tomorrow morning and hook everything up and drive it on the trailer.  Pleeeenty of time.
this 4.8 is disgusting. Just how i like them
cruisermatt
cruisermatt Reader
10/21/21 3:20 p.m.
Right on time
jfryjfry
jfryjfry SuperDork
10/22/21 6:56 a.m.
Awwwwww yeeeeaaahhh
cruisermatt
cruisermatt Reader
10/22/21 8:44 p.m.
Well we made it here, survived auto-x and came in 2nd for drag racing behind the Nelsons mind boggling repeated 9.06.
We went 12.3 twice (which is way slow for this setup), first run leaving off footbrake and short shifting, 2nd run leaving off the trans brake but sending it with a 4k rpm launch which spun.
however in our haste putting the car together we missed the lower wastegate hose so it was essentially pinned shut the entire time.
This wouldn't be a issue with the old turbo but.. last minute we did decided to do a turbo upgrade with our newfound budget room.
result:
Both drag race runs it hit 30 lbs boost at the end of the track, on the second run it hurt something. Smoke machine.
it still runs though!
Completely stock bmw rear axles/diff still together!
jfryjfry
jfryjfry SuperDork
10/23/21 12:46 p.m.
So glad to hear!
cruisermatt
cruisermatt Reader
10/23/21 10:15 p.m.
as soon as we got back this evening and unloaded everything we did a compression test, found #7 had 0, hoped it was just a head gasket, pulled the head, found a melted piston. We put the head back on and drove it into the shop where it will sit until it gets parted out.
if it was just the head gasket we would take it to the local test and tune and see if what it can really do with some real tuning but i dont have time or desire to do yet another engine in/out in this car.
We are pretty confident this car would easily go 10's with a mild launch and just spring pressure in the gate.
It might be neat to basically do over this car with a slightly nicer one, better suspension and auto-x tires, and less power. I think it could have had the potential to be a really high finisher with what we know now. Maybe one day!
who wants to buy this roller smiley
cruisermatt
cruisermatt Reader
10/23/21 10:23 p.m.
The really big lessons from our wastegate failure was not that we had it hooked up wrong, it was not stopping to check the logs between runs and immediately hopping back in the lane after the first run. If i had stopped to check the log after the first run, and not been impatient and immediately got right back in the lane and went for a 4k-rpm transbrake launch, we would have clearly seen the boost ramp up solidly to 30lbs and pin the Map sensor on the first run and caught it before it hurt anything.
the 2nd run picked up enough to hit 280F IAT and 30lbs for 1.7 seconds, 13.5 AFR, ouch
cruisermatt
cruisermatt Reader
10/26/21 11:38 p.m.
It is just a piston... I could probably have the motor out, piston swapped, motor back in and running again in a few hours solo...
car50
car50 New Reader
10/27/21 1:50 a.m.
It is a pity that it is dismantled, let it be repaired, but whoever does not drive it does not break, I wish that you could continue to ride if you fix it and let it drive as much time as possible :)
Andy Neuman
Andy Neuman SuperDork
10/27/21 6:16 a.m.
Great talking to you guys this weekend.
You guys are definitely learning quickly with this car. I expect you guys to bring something even crazier in the future.
cruisermatt
cruisermatt Reader
10/31/21 9:02 a.m.
In the second pic you can see the new turbo oil feed we did the last minute before Challenge. It was the power steering hose from the van. The metal tube runs perfectly down the length under the intake manifold, like factory
cruisermatt
cruisermatt Reader
10/31/21 4:10 p.m.
Stampie
10/31/21 4:47 p.m.
In reply to cruisermatt :
I'll double your asking price and buy it as is.  Can pick up tomorrow evening.
cruisermatt
cruisermatt Reader
10/31/21 8:54 p.m.
In reply to Stampie :
Good one! I wouldn't sell the ECU for $600 laugh
cruisermatt
cruisermatt Reader
11/3/21 8:56 a.m.
cruisermatt
cruisermatt Reader
11/7/21 12:51 p.m.
So far so good. The car has exactly the same parts as it had in Gainesville, this pass was on on a 6spi wastegate spring only.
jfryjfry
jfryjfry SuperDork
11/7/21 1:54 p.m.
Excellent.  Very glad you didn't throw in the towel on it
cruisermatt
cruisermatt Reader
11/7/21 4:47 p.m.
Way more left in it too. Keep in mind this is with the completely stock 4.8 (besides valve springs)
Andy Neuman
11/7/21 8:30 p.m.
Nice times, next year you will be ready.
cruisermatt
cruisermatt Reader
12/1/21 11:01 p.m.
Pulled the car cover off today and took it to lunch to keep everything moving.
golfduke
golfduke Dork
12/2/21 10:43 a.m.
wow, that's not helping the fact that I have a 4.8 shortblock in my garage right now... holy carp!
cruisermatt
cruisermatt Reader
12/4/21 12:34 p.m.
Next motor combo is planned.
Im selling the 799 heads off the original aluminum 5.3 block which will fully recoupe that,
The current 4.8 long block is fully recouped
So going to legitimately  clean out the aluminum 5.3 block and put the 4.8 rotating assembly and heads in that, aluminum 4.8. Going to actually do it right. I have new rod and cam bearings from amazon warehouse deals.
The current valve springs are really nice Riverdale speed springs but they were $145 and way overkill for this car, going to loose those and find some takeout OEM springs like LS6 or LS3 that will be way cheaper.
and then since the 5.3 is set up for front cam sensor i can use a LS9 cam which are usually <$100. I may just stick with the stock cam though as it may be fine for our goals. Unfortunately my $50 BTR Turbo cam is completely wrecked.
so, aluminum 4.8 with cam/spring upgrade for <$200. that gets us some power  and weight back without a big budget chunk.
$80 gt45 turbo is going back on for now as i have to return the billet 78/75 to another build :(
the original 2020 setup was $150 long block, $150 cam, $145 valve springs so this is much better budget wise
other mods for the next few months are deleting the front cage section to get some weight and budget back, and switching the car from the MS3 Goldbox to a regular Microsquirt (goldbox going on the 2JZ Fox)
1 ... 4 5 6 7
AgD1vQFCIwAuHuXDN7uThwHgUnjYQeFZybrC8TWmVPlbcVoWwO9sEN4HfMtNlOEA
