Per Schroeder
Per Schroeder Technical Editor/Advertising Director
4/25/11 1:53 p.m.
not ours..no affiliation:
http://jacksonville.craigslist.org/cto/2335238312.html
DILYSI Dave
DILYSI Dave SuperDork
4/25/11 2:01 p.m.
killerkane
killerkane Reader
4/25/11 3:12 p.m.
Woah. How much would it cost to tow that to South Dakota?!?!
killerkane
killerkane Reader
4/25/11 3:16 p.m.
I can't stop thinking about this. Oh the possibilities!
Per Schroeder
4/25/11 3:36 p.m.
killerkane wrote: Woah. How much would it cost to tow that to South Dakota?!?!
Step 1: Build a Trebuchet.
killerkane
killerkane Reader
4/25/11 5:33 p.m.
We did that in physics a few years back, except ours only launched ping pong balls not Mini Coopers.
metalman
metalman Reader
4/25/11 6:07 p.m.
I dont think thats a 'Cooper' but it is a Mini and its a cool project.
Cooper is to Mini what SS is to Chevelle. Sorta.
BoxheadTim
BoxheadTim GRM+ Memberand SuperDork
4/25/11 6:46 p.m.
Generally easy way to check if it's a Cooper is to check if it's got dual tanks - most (old) Coopers had those IIRC.
3brokenhondas
3brokenhondas New Reader
4/25/11 6:54 p.m.
Needs flares, wide 13" minilites, and vtak!
metalman
metalman Reader
4/25/11 7:54 p.m.
BoxheadTim wrote: Generally easy way to check if it's a Cooper is to check if it's got dual tanks - most (old) Coopers had those IIRC.
Yep, and a few other things like front discs and a 1275 motor.
metalman
metalman Reader
4/25/11 7:55 p.m.
3brokenhondas wrote: Needs flares, wide 13" minilites, and vtak!
Nooo, 10"s are the way to go for authentic classic Mini fun. ;-)....along with some group 2 flares...err...uhh...arches as the Brits call them.
BoxheadTim
4/25/11 8:04 p.m.
Front disks yes, but they can be retrofitted fairly easily to a regular one. They also had several other engine size (998 and 1071, from memory) so the presence of a 1275 isn't really a sign it's a Cooper. Plus, the 1275 lived on for a very long time and is a popular and cheap retrofit, at least in the UK.
DILYSI Dave
4/26/11 7:44 a.m.
I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it. I really shouldn't buy this and drop my turbo civic engine in the back of it.
RossD
RossD SuperDork
4/26/11 8:20 a.m.
All work and no play makes DILYSI Dave a dull boy.
dorri732
dorri732 New Reader
4/26/11 8:41 a.m.
I just wish someone would buy this and drop their turbo civic engine in the back of it.
914Driver SuperDork
4/26/11 9:05 a.m.
I believe some Clown already did that.
metalman
metalman Reader
4/26/11 9:47 a.m.
BoxheadTim wrote: the 1275 ... is a ... cheap retrofit,
Not here. Not any more.
I think you will find that the 1275 was the only motor in the 1971 Cooper. 997s, 1071s etc were found in some earlier models.
metalman
metalman Reader
4/26/11 9:50 a.m.
Also, in the USA about 90% of Minis are advertised as 'Coopers' and arent.
The disc brake kits are easily obtained BUT in the USA are expensive for the correct 7.5 Cooper S type, like $1400ish, even used run $500-700
93EXCivic
93EXCivic SuperDork
4/26/11 10:09 a.m.
Not here. Not any more. I think you will find that the 1275 was the only motor in the 1971 Cooper. 997s, 1071s etc were found in some earlier models.
??? I have always seen 1275s for fairly cheap.
metalman
metalman Reader
4/26/11 10:12 a.m.
If they are a Mini 'lump' you better be buying them....or sending them my way. I'd buy some cheap ones. Plural.
93EXCivic
93EXCivic SuperDork
4/26/11 10:15 a.m.
metalman wrote: If they are a Mini 'lump' you better be buying them....or sending them my way. I'd buy some cheap ones. Plural.
Won't the ones from the MG 1300 fit?
metalman
metalman Reader
4/26/11 10:18 a.m.
You need more then just a block to swap into the Mini, but if you have a complete Metro fwd swap they are still pricey.
metalman
metalman Reader
4/26/11 10:22 a.m.
If you run across any cheap 1275 Cooper lumps I'll take 6 immediately. And then 10 more after that. ;-)
93EXCivic
93EXCivic SuperDork
4/26/11 10:26 a.m.
metalman wrote: You need more then just a block to swap into the Mini, but if you have a complete Metro fwd swap they are still pricey.
What else do you need other then the block for the swap? I was under the impression that the any A-series will bolt to pretty much any other A-series transmission.
metalman
metalman Reader
4/26/11 10:33 a.m.
Cooper lump > Metro lump in value. But even a Metro 1300 lump has value. Pieces and parts are not the same as the motor/lump.
For exact swappage of individual doodads consult the Mini forums. ;-)
BnJR9WR8A8XWbMEecIklVTsU7b9iAH8JKArORSRZphtRrO6qYQRIoYeqwpzi6NQM
