Sine_Qua_Non
Sine_Qua_Non SuperDork
1/10/20 11:05 p.m.
RossD
RossD MegaDork
1/11/20 6:30 a.m.
That looks pretty rust free for $500, at least from my view from Wisconsin.
Build A: 2 weber DCOE, vintage-ish build.
Build B: Grab a Contour SVT engine and transaxle and put it in the boot!
alfadriver
alfadriver MegaDork
1/11/20 8:20 a.m.
In reply to RossD :
And easier SVT build would be from a Focus- the ZTEC powertrain supposedly drops into that hole.
DeadSkunk  (Warren)
DeadSkunk (Warren) PowerDork
1/11/20 8:43 a.m.
In reply to alfadriver :
That would make a Fiesta pretty entertaining. 170 HP and 1800 lb.should work well.
alfadriver
alfadriver MegaDork
1/11/20 8:51 a.m.
In reply to DeadSkunk (Warren) :
knowing what is in the calibration- there's a little more power left (170 was to make 100k miles without any stuff breaking).  Just like I'd wager there's some weight left.  My same era Alfa had 75lb worth of bumper on each end....
So maybe 170whp and 1700lb.  That would be a blast.
and add this cam cover-
Pete Gossett
1/11/20 6:14 p.m.
Forget the drivetrain, someone should paint it up like the General Lee, but call it the "Yee Ha Ghia".
jfryjfry
jfryjfry Dork
1/12/20 9:25 p.m.
Aaaahhh memories!
first car was an Orange 78 fiesta S
Woody
Woody GRM+ Memberand MegaDork
1/12/20 10:05 p.m.
jfryjfry said:
Aaaahhh memories!
You had the sway bar!
ultraclyde
ultraclyde PowerDork
1/13/20 6:00 a.m.
alfadriver said:
In reply to RossD :
This is the kind of information that could put a strain on my marriage.
RossD
RossD MegaDork
1/13/20 7:44 a.m.
ultraclyde said:
alfadriver said:
In reply to RossD :
I believe a Zetec (normal and SVT) bolts to the transaxle. The starter moved positions but cut the 'wing' off of the aluminum oil pan and use the xflow position. I've heard there is an early Contour/Mystique that has the lower position starter just like the typical xflow position.
Dont know how strong the transaxle is, however.
Saron81
Saron81 Reader
1/22/20 1:22 p.m.
In reply to ultraclyde :
It's not a bolt in affair, and I wouldn't trust the 4 speed or the axles with 170+hp. That said.... it does fit. I made custom mounts on frame side to use all stock Focus mounts, except for a custom lower mount. Did not use the Fiestas factory cradle/mount setup. The stock 1.6 50hp would commonly break those mounts, lol. Here's mine:
Knurled.
2/8/20 8:46 p.m.
FWIW, in the late 70s, Ford tested these with BDAs to see if they could be a suitable replacement for the MkII Escort.
240hp in a Fiesta...  Apparently they could get them to go, or they could get them to turn, but with the tires and suspension of the time they could not get both with the same chassis/tire setup.
einy
einy HalfDork
2/11/20 6:47 p.m.
Seeing that article made me really miss the old C&D ....
matthewmcl
matthewmcl Reader
2/11/20 7:23 p.m.
Thanks for posting the old article; that is really cool.
spitfirebill
spitfirebill MegaDork
3/9/20 7:18 a.m.
alfadriver said:
In reply to RossD :
I think that would be a lot more productive than trying anything on the original engine.
pinchvalve
3/9/20 8:02 a.m.
I saw a shell for $500 and a wrecked Fiesta ST for sale in the same week once. Made me think about the possibilities.
jimbbski
jimbbski SuperDork
3/12/20 6:33 p.m.
IF I were to do a swap it would be the the Fiesta ST drive train. I already have a '79 Fiesta that's pretty solid. I plan on rebuilding the stock 1.6L Kent this summer as I just like to see what I can do with it.  This is my 4th Fiesta but first one since 1995.
5hn3P2w6lE1JU9XJuMzQ8T5McNkBrbsyOOqbBvvHX1yxWH0VDiJ45xgblRHoGq0M
