16vCorey
16vCorey PowerDork
7/16/13 10:26 a.m.
Bump.
This car is going to the scrapper in approx. one month if no one wants it. I still have lots of parts left.
redhookfern
redhookfern Reader
7/16/13 1:57 p.m.
Any idea if some of the electrics still work on the car? My rear license lights have all but corroded away and could also use the analog clock if it works. Also, the latch on the sunroof (the one that is attached to the front of the sunroof panel), ash tray? I know, all random things, but all random things that my '83 seems to be lacking.
16vCorey
16vCorey PowerDork
7/16/13 2:18 p.m.
I should still have the license lights, sunroof latch piece, and ash tray. I saved the clock for mine! $30 shipped for those parts?
16vCorey
16vCorey PowerDork
8/21/13 10:41 a.m.
It's getting cut up next week if no one wants a shell! Still have a bunch of part too.
AngryCorvair
AngryCorvair GRM+ Memberand PowerDork
8/21/13 12:07 p.m.
have you posted on the Spec 944 board?
M030
M030 Dork
8/21/13 1:47 p.m.
How much for the wiper motor?
  • Brian
16vCorey
16vCorey PowerDork
8/21/13 4:50 p.m.
Wiper motor is already sold.
16vCorey
16vCorey PowerDork
8/21/13 4:51 p.m.
AngryCorvair wrote: have you posted on the Spec 944 board?
Nope. What's the best one? Or is there only one?
AngryCorvair
8/21/13 9:14 p.m.
idk, never looked for a Spec 944 board. your google is probably as good as mine.
dean1484
dean1484 GRM+ Memberand PowerDork
8/27/13 11:51 a.m.
You don't by chance have a cooling fan motor?
I also need the Wiper motor but I think I saw that was gone already.
How is the trans?
What about the gas tank? Don't know how you w0uld ship that though unless it was squeaky clean.
16vCorey
16vCorey PowerDork
8/27/13 4:37 p.m.
I do have the cooling fan. Do you just need the motor? I've got one or two of those laying around. I'm planning on swapping the one from my parts car to my driver, because the one in my driver had a crack in the shroud. It's been repaired and hasn't given me any problems in the last four years, but I'd like to swap it out anyway.
The trans is fine. I bought it with a bad clutch, but the PO said it didn't have any problems, and I believe that the 103k miles is actual. I can drain the fluid to make sure there's no shavings or anything if you're interested.
I could probably ship the tank if I have it boiled/flushed, but I doubt there's any way that I could get it clean enough to ship myself. I think it's about $60 to have one flushed.
16vCorey
16vCorey PowerDork
8/27/13 4:46 p.m.
Oh, and the wiper motor is already sold, but I might have another laying around. Let me check on that.
dean1484
8/28/13 11:13 a.m.
I need the early style wiper motor (late one has a different plug and mounting I think)
I only need the motor for the cooling fan. I think the blades can be removed as well. If it is a 5 blade fan I will take it with the fan blade attached. But it really does not matter I can swap my bade over. I have had to replace these in the past and if I remember they are easy to swap the blades around.
The trans is really not a necessity. I have on open dif 951 trans in my car now and I kind of miss the gearing of the NA trans. I have an early NA trans in the shed that needs a carrior bearing for the dif / stub axle and I have just not got around to replacing it.
Ohya do you have the idle speed control motor by chance?
dean1484
9/4/13 11:11 a.m.
Just bringing this up again as I never heard form you.
DrBoost
DrBoost PowerDork
9/6/13 9:05 a.m.
Are you willing to cut the battery tray out for me? I'll send you measurements and pics of what I need.
M030
M030 Dork
9/30/13 11:43 a.m.
Dean, I have the cooling fan motor you need.
dean1484
9/30/13 12:44 p.m.
Sweet how much? (PM Me if you want)
M030
M030 Dork
9/30/13 1:04 p.m.
Dean, $70 shipped to you
dean1484
9/30/13 2:13 p.m.
Will do. Send me a paypal address. My email is dsmith@radio.fm
16vCorey
16vCorey PowerDork
10/1/13 8:32 a.m.
Sorry, I haven't checked this thread in a while. If he falls through I have the fan, and last night I found an early wiper motor in the garage. The plastic gear is stripped, but the motor is good. If your gear is good you can swap it out in a couple minutes.
FmkB38dAqBeAFMZnnMObFihZAqJYcbUwAHifoltdG8NWl4EWPyqwCPOzvDhwKlet
