DeadSkunk  (Warren)
DeadSkunk (Warren) PowerDork
5/12/20 9:53 a.m.
wheels777 said:
It just came to me that the OP was asking a specific question.  Where do you want this thread to go?  Should it morf into a challenge drag race thread?  Or are you hoping for more info on the NA efforts for your car?
It was just one of those curiosity thoughts that pop up occasionally, but I do wonder how quick I can build a car. At this point it will be NA, despite Calvin's prodding to turbocharge all the LSes. I will ask a specific question though, Andrew. If you plug the stats for one of your Challenge cars into one of the on-line calculators ( I use the Wallace Racing one) how close do your actual performance numbers come to the calculated ones?
wheels777
wheels777 SuperDork
5/12/20 2:14 p.m.
We use Wallace to conversation and trends. But they typically don't do much for you if you focus on ET. But if the look at MPH and HP there is a relatively decent correlation. The issue with ET is easy to understand why they don't work if you watch Calvin's video on the torque converters.
DeadSkunk  (Warren)
5/12/20 2:32 p.m.
I watched that converter video and was rather surprised by how big a difference there was.
I've been playing with numbers on the Wallace calculator to see what gear I should be looking for. Currently the rear end has a 2.73 ratio and it'll putter through the traps at about 4600 RPM. Me thinks it needs a little more oomph.
wheels777
wheels777 SuperDork
5/12/20 3:51 p.m.
How much converter slip are you adding?
DeadSkunk  (Warren)
5/12/20 4:06 p.m.
In reply to wheels777 :
10-15% ?? That a reasonable number?
wheels777
wheels777 SuperDork
5/12/20 4:18 p.m.
Depends on the "stall". Most of our good ones are 6-9. We have a high end unit that goes 2%. The cheap Challenge friendly ones are 10-15%.
Stampie (FS)
Stampie (FS) GRM+ Memberand UltimaDork
5/12/20 4:38 p.m.
This reminds me of a conversation Andrew and I had a few years ago when I was trying to figure out the math theory of drag racing.  I had spent days doing calculations and thought I had it down before our phone call.  Andrew did those days of calculations I swear so fast it had to be in his head and then when something didn't agree with what I had gotten he says "how much did you allow for converter slip?"  Thanks Andrew for all the help you've been willing to give me and others and for leading the way so that we can tell people about the $2000 car that runs 9s.
DeadSkunk  (Warren)
5/12/20 4:57 p.m.
I've been watching for a stall in the 2500-3500 range, but keep getting to them in 2nd or 3rd place. The search continues as with the other important bits I still need to find.
wheels777
wheels777 SuperDork
5/12/20 5:53 p.m.
What power level?  That thing won't slip much. Maybe 5-7%.
DeadSkunk  (Warren)
5/12/20 6:33 p.m.
It's 290-300 HP stock. I do have a bigger cam , but it will require new valve springs ,timing cover and cam sprocket to be used. It'll come down to how I'm doing on budget whether it gets used or not. Otherwise ,the motor will have little done to it beside the shorty headers and a simple air intake. I keep looking for a cheap nitrous kit to possibly use. I'll be trying to keep the weight down to compensate for the lack of power. It's primary use will be autocross, so everything will be biased that way.
ckosacranoid
ckosacranoid SuperDork
5/13/20 5:19 p.m.
Hell, I would settle in the drags for next time beating 17's. I have a few 18's so far with bone stock and both V8 and boxer 4.
Congrats Andy and some very killer rides. I thought that the 2017 run was in the 9.40 something? I will have to go back and watch the video of the pass and look. I thought it was something like 143mph at 9.43 i thought. It was one hell of a run though. That DSM car look like it will be very bad to the bone for sure with that v8.
You guys are the one team I speak of when people talk about drag racing, super cheap cars that will smoke anything for chump change, and parts left over from other projects that are even more fun.
Ashyukun (Robert)
Ashyukun (Robert) GRM+ Memberand UberDork
5/14/20 8:24 a.m.
I'd settle for having a car actually run the drags at full potential for once... the two cars I've taken myself have a) had the transmission seal start leaking when I finally figured out when to manually shift the automatic transmission properly and b1) the turbo bypass actuator lever came loose on the 1/2 shift so I had no turbo for most of the run and b2) the drags were outright cancelled.
wheels777
wheels777 SuperDork
6/2/20 8:14 a.m.
wow. Does turbo include supercharged or have there really been no supercharged challenge cars in the 11s? I love all the data you keep on the event.
Also, we might need a new sticker or something that says "its just data". I love it
You have us thinking about doing a Supercharger project just to break the trend.
6/2/20 11:44 a.m.
AWESOME
Patrick (Forum Supporter)
6/2/20 11:59 a.m.
Nah keep playing with turbos
Crazier
Crazier Reader
6/2/20 2:26 p.m.
In reply to Robbie (Forum Supporter) :
We should chat about twin charging. Or even just supercharging.
There are a lot of options.
Turbo does make a better 1/4 mile option. Supercharhed is better for a streetcar and can be better for autocross.
I have a bunch of friends in the SC word and probably the two or three guys at the top of the twincharging game
The set up I am copying made almost 600 crank horsepower maxing out 80# injectors. Turbo only made max boost at 1.3 seconds and on twincharhed made it in .58 seconds and during that .58 seconds the supercharger made more power where the turbo would only habe made lag.
03Panther
03Panther HalfDork
6/3/20 8:08 p.m.
wheels777 said:
We have details on many aspects of the event.  Hope sharing this does not come across the wrong way
Rank Finish # Team Rep Year Manu Model ET Event
1 6 7 Andrew Nelson 1974 Datsun 260Z 9.521 2017 Nitrous
2 7 7 Calvin Nelson 1980 Pontiac Sunbird 9.847 2019 Turbo
3 1 7 Andrew Nelson 1947 Volkswagen Beetle 10.263 2016 Nitrous
4 1 7 Andrew Nelson 1968 Volkswagen Beetle 10.396 2015 NA
5 2 7 Andrew Nelson 1968 Volkswagen Beetle 10.571 2008 NA
6 9 7 Andrew Nelson 1974 Datsun 260Z 10.572 2006 NA
*** 2 7 Andrew Nelson 1968 Volkswagen Beetle 10.582 2011 NA
7 11 7 Andrew Nelson 1977 Chevy Nova 10.659 2004 NA
8 9 7 Andrew Nelson 1969 MG MGB 10.678 2010 NA
9 3 7 Andrew Nelson 1980 Pontiac Sunbird 10.776 2014 Nitrous
10 2 10 Matt Step 1989 Mitsubishi Mirage GT 10.820 2010 Turbo
11 11 7 Andrew Nelson 1947 Volkswagen Beetle 10.821 2009 NA
12 6 57 Calvin Nelson 1963 Studebaker Lark 10.924 2019 Turbo
13 1 14 Stephen DeFayette 1988 Mazda RX-7 10.926 2006 Nitrous
14 11 7 Andrew Nelson 1947 VW Beetle 10.950 2013 NA
15 4 57 Calvin Nelson 1980 Pontiac Sunbird 11.010 2017 Turbo
16 1 50 Ed Malle 1987 Ford Mustang 11.031 2014 Nitrous
17 2 49 Ed Malle 1987 Ford Mustang 11.103 2013 Nitrous
18 2 53 Ed Malle 1995 Ford Mustang 11.15 2019 Turbo
19 1 63 Erik Lawson   Datsun 280Zx 11.19 2004 Nitrous
20 4 08 Vince Coleman 1969 MG B 11.249 2014 NA
21 1 8 Patrick Culkin 1988 Dodge Shadow ES 11.319 2013 Turbo
22 11 7 Andrew Nelson 1962 Fiat 118G 11.465 2005 NA
23 13 68 Matt Step 1989 Plymouth Colt E 11.468 2006 Turbo
24 3 63 Erik Lawson   Datsun 280ZX 11.486 2003 Nitrous
25 4 37 Matt Step 1990 Plymouth Colt 11.567 2008 Turbo
26 5 57 Calvin Nelson 1963 Studebaker Lark 11.622 2016 NA
27 2 2 Cliff Sebring   Dodge Omni 11.629 2003 Turbo
28 4 45 Stephen DeFayette 1988 Mazda RX7 11.632 2005 Unk
29 2 95 Ed Malle 1995 Ford Mustang 11.636 2017 Turbo
30 4 21 Patrick Culkin 1988 Dodge Aries 11.640 2010 Turbo
31 1 58 Jeremy Butts 1988 Mazda RX7 11.676 2005 Unk
32 1   Patrick Culkin 1988 Dodge Aries 11.694 2012 Turbo
33 5 18 Nathan Crisman 1990 Eagle Talon TSi 11.737 2004 Unk
34 6 25 Patrick Culkin 1988 Dodge Shadow 11.745 2008 Turbo
35 2 22 Patrick Culkin 1988 Dodge Shadow 11.750 2009 Turbo
36 9 17 Steve Cammick   Ford Mustang 11.797 2004 Unk
37 1 75 Adam Jabaay 1988 Honda CRX 11.840 2009 Unk
38 3 99 Cliff Sebring   Dodge GLH 11.846 2005 Turbo
39 5 67 Matt Step 1990 Eagle Talon Tsi 11.954 2005 Turbo
40 3 47 Lon Zeigler 1969 MG B 11.957 2016 NA
41 2 0 Cliff Sebring   Dodge Omni 11.959 2004 Turbo
42 3 75 Adam Jabaay 1988 Honda CRX 11.987 2008 Unk
43 4 21 Matt Wojtkowiak 1994 Pontiac Trans Am 11.994 2013 Unk
44 5 17 Cliff Sebring 1996 Plymouth Neon 11.998 2015 Nitrous
Its just data
Will Sonnet said: "no brag, just fact"   smiley
wheels777
wheels777 UltraDork
10/25/21 7:56 p.m.
Warren there a new number 1 for the list.  Some dorky kid from PA I think.
DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
10/25/21 8:25 p.m.
LOL....I trust my memory in the other thread but didn't remember starting this thread at all.......I must be getting old. So, 10.396 is the target then.....I can do that with my 5.3 , I just need to get the car weight down to about 800 pounds.....piece of cake.
Edit: ....and Thank You for digging this up.
wheels777
wheels777 UltraDork
10/25/21 8:33 p.m.
It came up at the event this year about 5 times.  Didn't take long to dig it out the second time.
sleepyhead the buffalo
10/25/21 8:48 p.m.
dunno if you want to update 'the'/'your' sheet... but based on this article:
https://grassrootsmotorsports.com/articles/2000-challenge-20-years-wild-budget-builds/
I think it's reasonable to update the two "Jabaay" / "CRX" entries to "turbo" from "unknown"?
evildky
evildky SuperDork
10/26/21 9:56 a.m.
RankFinish#Team RepYearManuModelETEvent 167Andrew Nelson1974Datsun260Z9.5212017Nitrous277Calvin Nelson1980PontiacSunbird9.8472019Turbo317Andrew Nelson1947Volkswagen Beetle10.2632016Nitrous417Andrew Nelson1968Volkswagen Beetle 10.3962015NA527Andrew Nelson1968Volkswagen Beetle10.5712008NA697Andrew Nelson1974Datsun260Z10.5722006NA***27Andrew Nelson1968Volkswagen Beetle10.5822011NA7117Andrew Nelson1977ChevyNova10.6592004NA897Andrew Nelson1969MGMGB10.6782010NA937Andrew Nelson1980PontiacSunbird10.7762014Nitrous10210Matt Step1989MitsubishiMirage GT10.8202010Turbo11117Andrew Nelson1947Volkswagen Beetle10.8212009NA12657Calvin Nelson1963StudebakerLark10.9242019Turbo13114Stephen DeFayette1988MazdaRX-710.9262006Nitrous14117Andrew Nelson1947VWBeetle10.9502013NA15457Calvin Nelson1980PontiacSunbird11.0102017Turbo16150Ed Malle1987FordMustang 11.0312014Nitrous17249Ed Malle1987FordMustang11.1032013Nitrous18253Ed Malle1995FordMustang11.152019Turbo19163Erik Lawson Datsun280Zx11.192004Nitrous20408Vince Coleman1969MGB11.2492014NA2118Patrick Culkin1988DodgeShadow ES11.3192013Turbo22117Andrew Nelson1962Fiat118G11.4652005NA231368Matt Step1989PlymouthColt E11.4682006Turbo24363Erik Lawson Datsun280ZX11.4862003Nitrous25437Matt Step1990PlymouthColt11.5672008Turbo26557Calvin Nelson1963StudebakerLark11.6222016NA2722Cliff Sebring DodgeOmni11.6292003Turbo28445Stephen DeFayette1988MazdaRX711.6322005Unk29295Ed Malle1995FordMustang11.6362017Turbo30421Patrick Culkin1988DodgeAries11.6402010Turbo31158Jeremy Butts1988MazdaRX711.6762005Unk321 Patrick Culkin1988DodgeAries11.6942012Turbo33518Nathan Crisman1990EagleTalon TSi11.7372004Unk34625Patrick Culkin1988DodgeShadow11.7452008Turbo35222Patrick Culkin1988Dodge Shadow11.7502009Turbo36917Steve Cammick FordMustang11.7972004Unk37175Adam Jabaay1988Honda CRX11.8402009Unk38399Cliff Sebring DodgeGLH11.8462005Turbo39567Matt Step1990Eagle Talon Tsi11.9542005Turbo40347Lon Zeigler1969MGB11.9572016NA4120Cliff Sebring DodgeOmni11.9592004Turbo42375Adam Jabaay1988HondaCRX11.9872008Unk43421Matt Wojtkowiak1994PontiacTrans Am11.9942013Unk44517Cliff Sebring1996PlymouthNeon 11.9982015Nitrous
Its just data
LOL, this doesn't surprise me at all. You probably have better records than GRM ;)
wheels777
wheels777 UltraDork
10/26/21 10:54 a.m.
In reply to evildky :
I sent them my file 2-3 years ago.  Look up the Challenge "did you know" thread.
IRprRwPERTxjod6Ai9bD1klZJPDlxNsRMxCVRcd4kD2Q2dAdkakKeF1beKkDu4KJ
