EvanB
EvanB GRM+ Memberand Dork
10/17/10 1:15 p.m.
My roommate has a 94 Jetta VR6 that he needs to get rid of.
It has the usual electrical gremlins: back windows don't work, ABS comes on randomly, turn signals don't flash when you hit the brakes, brake lights don't work but the rear turn signal lights come on instead, etc.
Second gear grinds but the engine runs ok last time I drove it. Waterpump and clutch were replaced in the last couple years. It has around 150k miles I think, battery is dead and so I can't check the odometer.
He would let it go for $800 or less or maybe trade for a running car.
Has stock BBS wheels, paint is peeling.
Gratuitous cell phone shot.
Travis_K
Travis_K Dork
10/17/10 1:59 p.m.
Those also have much better suspension geometry, brakes, swaybar, etc than the MK2 or other MK3, so if you want to build one that handles really well, put the suspension on a 4 cylinder mk2 and sell the Vr6.
Knurled
Knurled GRM+ Memberand HalfDork
10/17/10 5:12 p.m.
Or just fix the electrical problems. They sound simple.
EvanB
10/17/10 5:22 p.m.
Well he doesn't want to bother with it and I'm not going to fix it for him so it's up for sale as-is.
spoolin
spoolin New Reader
10/18/10 5:52 a.m.
Looks like you are in ohio. If in fla I would be all over this.
EvanB
10/18/10 9:08 a.m.
Yep. Columbus, OH
Knurled
10/18/10 10:12 p.m.
If i had $800 I'd be all over it.
BTW - Does it have red turn signals instead of separate amber ones? For some reason, people love to put single-filament bulbs in VWs with red turn signals, which causes the exact symptoms you've described...
EvanB
10/18/10 10:44 p.m.
I'm pretty sure they are yellow, I'll check it out sometime though.
John Brown
10/19/10 9:05 p.m.
Where was this when I needed a Beetle donor?
Grrrr....
EvanB
11/2/10 9:04 p.m.
Well we put a good battery in it (doesn't come with the car) and it starts intermittently. Usually it will start but sometimes it won't even crank. The started was replaced (twice due to a faulty one the first time) three years ago.
I don't wanna deal with it. My roommate (the owner) doesn't wanna deal with it. $500 and it's yours. Either it will start or we can push start it if you bring a good battery.
Brett_Murphy
Brett_Murphy GRM+ Memberand Reader
11/5/10 4:29 p.m.
In reply to Travis_K:
I've wondered if that would work, but I sourced a bunch of 2.0 suspension parts for my car already. If I bite the bullet and go with coil-overs or something, maybe I'll switch. That would mean I wasted $250 bucks on a set of takeoff Neuspeed anti-roll bars, though.
Travis_K
Travis_K Dork
11/6/10 6:31 a.m.
The main advantage to the VR6 is more caster, although many other things help too. My friend is going to put full VR6 suspension (and boxster brakes) on his 91 gti tdi project.
vwcorvette
vwcorvette GRM+ Memberand Reader
11/6/10 11:47 a.m.
I'm guessing it needs an ign. switch (electric).
captain_napalm
captain_napalm Reader
11/15/10 4:04 a.m.
If it's still available in a couple of weeks, I may take a look at it.
jrw1621
jrw1621 SuperDork
11/15/10 7:49 a.m.
Knurled wrote: If i had $800 I'd be all over it. BTW - Does it have red turn signals instead of separate amber ones? For some reason, people love to put single-filament bulbs in VWs with red turn signals, which causes the exact symptoms you've described...
I too would be sure to check ALL the bulbs to see that they have the correct number of filaments.
I had a Rabbit with similar problems. The brake light should have been a double and rather was a single. Due to this, what appeared to be the brake lights stayed on all the time and when you hit the brakes the dashboard lights and the front amber lights came on. Took me forever to figure it out.
captain_napalm
11/18/10 10:02 a.m.
Contact info?
EvanB
11/18/10 10:55 a.m.
Message sent
DukeOfUndersteer
DukeOfUndersteer SuperDork
11/18/10 11:03 a.m.
+1 on the bulbs. Dual filament bulb problem. Either a single filament bulb in a dual element connection or the wrong dual filament bulb is in. Fairly typical problem as my co-worker says...
A0JJdSw2lSAyuT3oEeUiAw7OQFBAxPEnx3qBloIPxqakpd5OKvfOv6wYKnzXF6N6
