Anyone looking for a set of high compression Oldsmobile 215 cylinder heads complete including rockers and rocker arm covers, timing cover with original distributor, water pump, fuel pump and oil pump installed and included, and the 215 aluminum Oldsmobile block as well. Everything in fine shape.
Also have crank, needs to be cut or polished (light surface rust.)
Just $125 obo for everything. Pick-up only for the heavy stuff.
Here in Kingston, MA 02364
Thanks—
TC
Edit:
Just came up from down cellar, I think that I have the flex plate and pistons/with rods as well. If I do, I'll toss those in along with the stock air cleaner top and base.
