RoughandReady
RoughandReady HalfDork
8/30/14 9:44 a.m.
Unless otherwise noted, shipping is as follows: $15 for pistons, $10 for cams, $12 for cam and lifter kits, $5 for lifters, $4 for springs. Email at Roughandreadyrebuilds@gmail.com.
  1. ITM Aluminum HP SBC bare head castings. 64cc chamber, 200cc intake port. In/ex valve size: 2.02/1.60. Weight ~20 lbs each. $386 shipped/ea.
  2. New iron SBC Vortec bare head castings. 64cc chamber. In/ex valve size: 1.94/1.50. $269 shipped/ea.
  3. Flat top 350 pistons. Set of 8. Hypereutectic, coated skirt. 1.560 comp height. $126.
  4. Dome top pistons. Set of 8. Hypereutectic, coated skirt. 1.565 comp height. Pressed or floating pin. $216.
  5. Camshafts! Cam specs are as follows: In/ex duration (at .050), in/ex lift, in.ex lobe center. All are flat tappet.
a. 204/214, .281/.296, 107/117. $47.75 w/o lifters, $92.23 w/lifters.
b. 214/224, .295/.310, 107/117. $56.80 w/o lifters, $99.23 w/lifters.
c. 204/214, .281/.296, 110/110. $71.
d. 222/222, .298/.298, 110/118. $55.50.
e. 224/224, .300/.307, 114/114. $63.50.
f. 230/230, .320/.320, 107/117. $64.50 w/o lifters, $90.50 w/ lifters.
g. 234/244, .325/.340, 107/117. $73.60 w/o lifters, 103.20 w/ lifters.
h. 244/254, .339/.335, 107/117. $71.
i. 254/254, .323/.323, 110/118. $77.50.
j. 257/270, .329/.341, 108/116. $82.63.
  1. HD Valve Springs. Set of 16. 2.04 free height. 1.25 OD. 115 lbs closed, 300 lbs open. $20.50.
  2. HD flat tappet lifters. Set of 16. $63.80.
patgizz
patgizz GRM+ Memberand PowerDork
8/30/14 10:44 a.m.
lift numbers are at the lobe, so to get traditional advertised lift numbers we'd need to multiply by the 1.5 ratio of a standard rocker, so the .320 lift cam is equivalent to one advertised at .480, right?
is this stuff all new?
RoughandReady
8/30/14 2:04 p.m.
That's right. Multiply by stock rocker ratio or whatever rockers you have/want to run.
Everything is brand new.
I also have all the regular rebuild parts like bearings, gaskets, seals, valves etc.
patgizz wrote: lift numbers are at the lobe, so to get traditional advertised lift numbers we'd need to multiply by the 1.5 ratio of a standard rocker, so the .320 lift cam is equivalent to one advertised at .480, right? is this stuff all new?
HB3OrzC4E2ccSxmXmwVuNkSlzuTOTm7FFf6bRNBdeyZOAidGq9YK9YjrppV0Dwjg
