Z06BLITZ
Z06BLITZ
7/12/16 8:17 p.m.
Hello, I have for sale a 1990 Honda accord, with a ton of parts. The car is a 5 speed manual with a few ticks over 200,000 on the chassis. The car has a new radiator, alternator, power steering rack, outer tie rods, it has an new starter and newer battery. The car wasc rally crossed for two seasons and is in sound condition. I recently performed a mild weight reduction of 94lbs removing the a.c., rear seats, spekers, cruise control, shaved the antenna and deleted the radio. This car Also come with parts not installed including a king motorsports cylinder head with adjustable cam gear, bisimoto valve springs, bisi moto custom cam(i have the spec sheet for tuning), three angle valve job, brass guides and swain tech thermal Barrier coating on the valves, exhaust runners and combustion chambers. Also there is nearly every part to rebuild an engine less the pistons. The oil pump has a balance shaft eliminating kit. And an extra block bored over to 86mm. With a set of floating wrist pin rods rated for 800hp. Include is an adapter plate for an h22 intake manifold, h22 intake comes with the car, it has no fuel rail but does have a throttle body, plan accordingly. Most misc. Gaskets grommits bits and bolts are included As new in box. Car also comes with turbo manifold, bov, rc 370 CC injectors, Car currently has broken half shaft but new half shaft comes with car. It does run and drive. This is a steal at $1500.
NordicSaab
NordicSaab HalfDork
7/12/16 8:42 p.m.
Wow! This has all the components of a perfectly bad decision.
Location?
Z06BLITZ
Z06BLITZ New Reader
7/13/16 5:25 a.m.
In reply to NordicSaab:
Leesburg, Florida.
keithj
keithj New Reader
7/13/16 8:34 p.m.
Fly and drive?
Z06BLITZ
Z06BLITZ New Reader
7/15/16 8:37 a.m.
In reply to keithj:
Yeah I can replace the axle and get you moving.
beans
beans Dork
7/15/16 12:02 p.m.
Total steal. The head alone is worth that.
Z06BLITZ
Z06BLITZ New Reader
7/15/16 2:31 p.m.
In reply to beans:
The head work cost about 1600 in parts and labor. The stock compression ratio is 8.8:1 the new block is prepared to use oem rsx pistons giving you about an 11:1 cr or you can go turbo, the manifold that come with is is from a dsm eclipse with the bolt holes redrilled, gaskets included for this manifold also.
bwMglbPaGn3aeTSxvvskyDflHmNQc4poodkK9KR5nLbi3ar7kBggNa1ngC8eEJIE
