MadScientistMatt
MadScientistMatt SuperDork
2/15/13 3:07 p.m.
The MS3-Pro Module puts the MS3-Pro circuitry on a board where we've replaced the AMPSEAL connectors with 0.100" pin headers. What's it for? Well, we will be using these as the core for MS3-Pro based MSPNPs, but we're also making them available to the public - why should we have all the fun? You could just solder a harness to one and call it an ECU, but this offers quite a few other possibilities. Here's some things you can use it for:
  • Design your own plug and play PCBs to adapt it to OEM wiring harnesses
  • Stuff it in a stock ECU case and solder it to the connector to comply with SCCA Street Touring rules or other class racing that allow any retuning device that fits in the OEM ECU case
  • Put it in your own case to make a private label ECU
  • Create a new PCB that adds extra features, like high current coil drivers or CAN based extensions
The MS3-Pro Module is approximately 5.5" x 3.5" - much easier to incorporate into your projects than trying to use a V3.57 main board, MS3 daughter card, MS3X, and all the other associated parts. And we offer volume discounts if you're making a production run.
See this link for more details about the MS3-Pro Module.
hGipDB9DHPxIVbfF6sLWvQnh7w0ElzvsQdZyXhGWqoTX8tIA3hE7f03WkKO2oAYi
