MadScientistMatt
MadScientistMatt SuperDork
8/16/12 10:16 a.m.
Ford 5.0 Mustang MSPNP
And it won't be the last, either.
This MSPNP fits '86-'93 5.0 Mustangs and '86-'88 5.0 Thunderbirds. It contains several improvements over our older package that included a MS2 with a wiring harness adapter. Some of the upgrades from the harness version include:
4 bar MAP sensor standard
Onboard barometric pressure sensor
Peak and hold injector drivers - lets you run low impedance injectors with the stock wiring harness
Knock sensor input and headphone jack for listening to knock sensor
Boost control output standard
2 step rev limiter
And more!
Ranger50
Ranger50 UltraDork
8/16/12 8:29 p.m.
How about 2.3T?
Oh nevermind, I should have read further.
MadScientistMatt
8/17/12 7:38 a.m.
2.3Ts are in the pipeline! If you've got a 2.3 Turbo project we can borrow, email websales@diyautotune.com - this unit could handle it with a few minor jumper changes, but we'd like to test it out and develop a base map.
Apexcarver
Apexcarver UberDork
8/17/12 7:40 a.m.
Just curious, is a 4.6 4v in the future? (96-98 cobra specifically)
MadScientistMatt
8/17/12 10:33 a.m.
Apexcarver wrote: Just curious, is a 4.6 4v in the future? (96-98 cobra specifically)
It's planned, but we think the 4.6s will be better served by an MS3 to get more inputs and outputs.
belteshazzar
belteshazzar UltraDork
8/22/12 2:30 p.m.
my '93 pickup has a 5.0. compatible?
MadScientistMatt
8/22/12 3:07 p.m.
belteshazzar wrote: my '93 pickup has a 5.0. compatible?
If it's an automatic, that would be a problem. A manual transmission would need somewhat different jumpers to make the peak and hold drivers work correctly, but we can set one up by special order.
belteshazzar
belteshazzar UberDork
12/19/12 4:19 p.m.
insurmountable?
MadScientistMatt
12/20/12 7:28 a.m.
Manual, no. Automatics, we'd need a test vehicle and probably a number of pre-orders, and it would be significantly more expensive.
9SfNMSBSVfTGiec0RT5NjOInlHY5mhvHE77b0ZTgOfBWC7u1XakSctZ5M7dwoMgq
