MadScientistMatt
MadScientistMatt PowerDork
1/17/17 12:29 p.m.
Order the MS3Pro Ultimate here
The MS3Pro Ultimate is a new ECU that pushes the MS3Pro design as far as it will go, with more inputs and outputs and the features customers with big horsepower engines have demanded. Here's a short list of what we added to the hardware:
  • Peak and hold drivers (software selectable 4/1 or 8/2)
  • 5 more analog inputs
  • Onboard 4 bar MAP and barometric pressure sensor connectors
  • 2 more VR conditioners - for Coyote cam sensors, vehicle speed sensors, and more
  • 7 more switched inputs
  • 4 more on/off or PWM outputs
  • Status indicator lights
And there's a new firmware upgrade out to support the MS3Pro Ultimate which you can also load to any current MS3Pro. The new firmware brings several new features:
  • CO2 dome pressure boost control
  • Four wheel traction control
  • More records in SD card data logs
This new version of the MS3Pro sells for $1499 with an 8' flying lead harness. For those who don't need all the extra I/O, we still have the entry leave MS3Pro available too.
ZwmfASjoSCzE7Am2WwXilGG8Owz5nLDLBJr0OdhY1YbcVNWeN92orS7j9HNL6Dqv
