Treasure Coast Miata
Treasure Coast Miata New Reader
10/27/15 1:41 p.m.
Were happy to announce a new, lower price for the our Hydraulic clutch replacement kit $56.
This kit is designed to provide you with all of the necessary parts to overhaul your Miata's fastest failing part, the clutch slave cylinder, and it's related components. Don't let your cars hydraulic clutch system leave you stranded!
While we have the slave cylinder for sale by itself, there are other things that should be done when it's time for your clutch hydraulic system maintenance, building a race car, or if you're planning to head out on the track. Slave cylinders can fail unexpectedly and ruin a track weekend you paid several hundred dollars for, so check out our kit which includes a recommended rehab plan for your clutch systems hydraulic system.
Here's what's included in our Clutch Hydraulic System Refresh Pack: •Exedy Clutch Slave Cylinder •Braided Stainless Steel Extended Length Clutch Line - get rid of that pain in the neck coiled line! •Exedy Clutch Master Cylinder (optional) •PENTOSIN Super DOT 4 Brake Fluid 250mL Bottle - the same as we use on all our Spec Miatas
You can find this kit on our web site here;
http://treasurecoastmiata.com/i-16080222-miata-clutch-hydraulic-system-replacement-kit.html
Treasure Coast Miata your new & used Miata Parts Super Store
TreasureCoastMiata@att.net
eL5hYIbGYoekwKn2YkGxLS2ed1Xxc6VctVZCzs06I3ljWWs7nsVtqDJGetUWYwzN
